Old 08-31-2018, 10:40 PM   #1
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Spacers on dual pattern wheels?
Bruh. I took 21 credits in math in College but I can't figure this shit out.
I want to run some spacers on my xxr 527 5x100/5x112 but I don't know how to make this work. What kind of spacers do I need? Or do I need adapters?
Usually it's pretty simple when it's one thread pattern but with wheels like these, how do you solve this issue?
carsebuco is offline   Reply With Quote
Old 09-01-2018, 01:27 AM   #2
Impureclient
Drives: 2015 FR-S
Why not just a 5x100 spacer? You're not using a solar powered calculator at night, are you?
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
MrDinkleman (09-01-2018)
Old 09-01-2018, 01:41 AM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What offset are your wheels? How much poke do you want?
5x100 hubcentric spacers with a hub bore 56.1 are what you want. Just figure out how thick.
I LIKE TIRES!
Old 09-01-2018, 01:41 AM   #4
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Given that the OEM bolts will stick out of the spacer and the wheel has no "room" for them, won't it just hit the inside of the wheels?
+42
I don't mind a little poke, but I want at least 100% flush
Old 09-01-2018, 01:45 AM   #5
MrDinkleman
Drives: 2016 Oceanic, "base" model
LOL I couldn't help but laugh.
MrDinkleman is offline   Reply With Quote
Old 09-01-2018, 01:49 AM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
+42
How wide are your wheels?
I LIKE TIRES!
Old 09-01-2018, 01:51 AM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Oh I see your question now! You're thinking of getting bolt on spacers. So the hub studs would sit in between the spacer's studs, and there wouldn't be a recess in the wheel to absorb the hub studs poking through the spacer because that's where the holes of the other bolt circle in the wheels are, except more radially outward.
Get bolt-through spacers and get longer studs pressed in the hubs.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
carsebuco (09-01-2018), Leonardo (09-01-2018)
Old 09-01-2018, 01:51 AM   #8
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
18x8
Old 09-01-2018, 01:57 AM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18x8
If you add a 20mm spacer, your wheels will poke like 9" +35 wheels. I have similar 18x8 +45 with a 1" spacer added. Im lowered 1" and have approx -1.4 front camber.
I'd get 20mm front and 25mm rear spacers. The wheels will have the same poke then. It will look great!
I LIKE TIRES!
Old 09-01-2018, 02:00 AM   #10
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
20/25 was my original plan, I have just never used spacers before and based on the google search I did, I could not figure out if the studs were gonna hit the back of my wheels and just not function...
The Following User Says Thank You to carsebuco For This Useful Post:
Old 09-01-2018, 02:07 AM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I had 5mm extended studs, but then got bolt on spacers. I cut them to length. It is possible.
I LIKE TIRES!
Old 09-07-2018, 12:08 PM   #12
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Yep, definitely did not work without alterations. The oem stud sticks out just enough to hit back of the wheel, causing a gap where there shouldn't be one.
Now I can either:
Cut oem studs
Buy new, shorter studs
Buy adapters (which for the cost isn't worth it)
Buy new wheels altogether and sell mine. This might be worth it considering I'm not too sure about cutting up the studs
Old 09-07-2018, 12:38 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
... or just get longer wheel studs and open-ended lug nuts to use with your spacers.
If installing studs is too much work for what you want to do, just get new wheels.
Old 09-07-2018, 12:50 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Is the issue just on the 20mm spacers or both?
I cut 10 studs in under an hour with a really dull old hacksaw. Cleaned up the tips with a file. I thread a nut onto the stud, cut it, unthread the nut which helps "clean up" the threads, and file the end carefully.
Replacing the studs is not that complicated. I did my front ones in about an hour. The rear takes a bit longer.
Spacers are a compromise for sure. Getting perfect width and offset wheels would be ideal. Sadly, the wheels I wanted only came in high (42 & 45) offsets. I have 5mm, 10mm, 12mm, and 25mm spacers to mess with.
I LIKE TIRES!
OEM STI wheels + Spacers spicyricecake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 07-14-2016 12:17 PM
Do spacers fit OEM Wheels ? Wil Scion FR-S / Toyota 86 GT86 General Forum 3 09-19-2015 10:33 PM
FS: OEM BRZ Wheels & 20/25mm Spacers idanvan Wheels and Tires 13 09-05-2014 12:50 PM
Spacers on OEM wheels? BRZlimited BRZ First-Gen (2012+) — General Topics 13 04-11-2014 07:47 PM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
