Old 08-29-2018, 10:20 AM   #1
D-rek07
Vibration above 80mph
Hi,
Current setup:
2013 BRZ MT, stock suspension, 68,000 miles, 17x9 Gramlight 57dr, hubcentric rings, 245/40r17 Michelin PSS tires, catless UEL header, tune.
Its my daily, I do track it.
There is a vibration in the chassis above around 80 mph. I feel it mainly through the seat. I had the wheels rebalanced since that was the low hanging fruit. It is not the front wheel bearings, i know what that feels like. The vibration does not come through the steering wheel or get worse when turning the wheel above 80.
The vibration is the same whether I'm in 6th gear or downshift to 5th or 4th going the same speed. So my initial inclination is that is not the driveshaft.
At some point I will put the stock wheels back on to completely eliminate the wheels/tires as the root cause.
I think that should be enough information but I'm sure you'll ask if you need something else.
If that doesn't fix it the only other thing it could be is the rear wheel bearings?
Any other ideas?
D-rek07 is offline   Reply With Quote
Old 08-29-2018, 10:26 AM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I am having the same issue. Though Mine manifested after my LS Swap. It's a somewhat speed based and gets worst as speed rises. Had my new driveshaft balanced multiple times. Wheels balanced and even replaced tires. Next up is trying road force balance to make 100% sure they aren't slightly bent. I replaced a cv joint on rear axle that helped quite a bit. I am starting to wonder if my other axle is broken/worn as well.
DustinS is offline   Reply With Quote
Old 08-29-2018, 10:26 AM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Alignment yet?
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
humfrz (08-29-2018)
Old 08-29-2018, 11:29 AM   #4
D-rek07
Originally Posted by 8RZ View Post
Alignment yet?
Hmm, I have not done a recent alignment. Good point, I will try that as well.
Old 08-29-2018, 11:40 AM   #5
Submarinesonce
Drives: Frs
im having this same issue
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 08-29-2018, 03:08 PM   #6
ShansBRZ
Drives: 2017 brz
I had the same problem when I put wheel spacers on. I tried reinstalling them a couple times but couldn’t get the shake to go away until I took them off.
ShansBRZ is offline   Reply With Quote
Old 08-29-2018, 03:31 PM   #7
D-rek07
Thanks for the input but I have no wheels spacers.
Old 08-29-2018, 03:41 PM   #8
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Rotor's could be warped, and tires could be cupped. I would check these too
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 08-29-2018, 03:45 PM   #9
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
I would start by checking alignment. I've found that this type of behavior can be caused by large deviations in alignment from left to right in either the front or the rear. It'd have to be off quite a bit, but it's completely possible. My factory alignment was off a surprising amount right off the dealer lot, after your 68k miles and hard driving it's worth having it checked.
Tristor is offline   Reply With Quote
Old 08-29-2018, 04:20 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
The driveshaft speed is fixed in relation to wheel speed. It's probably not the driveshaft but I figured I'd throw it out there just in case.
Does the vibration frequency seem to correspond to wheel speed, or is it about 4 times as fast? That'll narrow it down for sure.
Old 08-29-2018, 05:28 PM   #11
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
How do warped rotors play a roll unless you're braking?
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
JeremyR (08-29-2018)
Old 08-29-2018, 05:30 PM   #12
spike021
spike021's Avatar
Hi,
Current setup:
Any other ideas?
Dumb question but when you're experiencing this is it always on the same stretch of road?
The reason I ask is because from what you've said it's around 80mph, and to do that in most cases you'd be on a freeway/highway of some sort. Does this happen on all of the ones you travel on?
I know where I live there are some stretches of some freeways where there's kind of off-putting vibration, but it's easy to tell other cars are experiencing it too. It's just a result of the road being total crap with ripples or other imperfections; other roads that are nicely paved feel fine. Also with our suspension we feel imperfections much more easily than other cars.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 2 Users Say Thank You to spike021 For This Useful Post:
JeremyR (08-29-2018), Tcoat (09-18-2018)
Old 08-29-2018, 05:45 PM   #13
D-rek07
Makes sense, I didn't think that through properly.
Considering wheel speed is about 18 revolutions per second, I would say that it is closer to that than 72 revolutions per second (driveshaft speed).
Old 08-29-2018, 05:46 PM   #14
D-rek07
That was the very first thing I considered. It does it on all roads. Thanks for the thought tho.
Driveshaft vibration HELP ganz954 Engine, Exhaust, Transmission 24 11-26-2019 11:36 AM
Vibration and sounds Alupinski Issues | Warranty | Recalls / TSB 3 03-01-2016 08:58 PM
gas pedal vibration nfaj BRZ First-Gen (2012+) — General Topics 6 09-28-2014 03:25 PM
2600rpm vibration stueck9356 Issues | Warranty | Recalls / TSB 3 03-06-2014 12:06 PM
