Old 08-23-2018, 12:53 AM   #1
Aqualynx
Drives: 2018 Pure Red Toyota GT86 AT
Coolant is color black?
It’s only been less than 5 months since I purchased a new Toyota 86 2018 that I noticed that the coolant color in the reservoir is black. What should I do and why is it black?
Aqualynx is offline   Reply With Quote
Old 08-23-2018, 01:23 AM   #2
humfrz
Well, it shouldn't be black, blue but not black.
I'd suggest you take it back to the dealer and ask them to check it.
humfrz
The Following 4 Users Say Thank You to humfrz For This Useful Post:
22R (08-23-2018), kch (08-24-2018), Spuds (08-23-2018), Ultramaroon (08-23-2018)
Old 08-23-2018, 06:13 AM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I wonder if it's just mold... It could also be a sign of a leaky head gasket... In any case, coolant shouldn't be black... Take it back to the dealer to find out Lol
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 08-23-2018, 06:30 AM   #4
jfarkas
Drives: 2014 FR-S
Have you actually drawn any out to look at it in a clear cup to be sure it's black? Looking at my reservoir it appears black from the outside because the reservoir is translucent, but it's definitely blue coolant.
jfarkas is offline   Reply With Quote
The Following User Says Thank You to jfarkas For This Useful Post:
Spuds (08-23-2018)
Old 08-23-2018, 11:51 AM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Is it black because it's in the engine bay and there is shade making it appear black?
If you pop the lid, you can look inside and it should appear blue. Shine a flashlight to confirm.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Tcoat (08-23-2018)
Old 08-23-2018, 12:25 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
^that
Old 08-23-2018, 11:31 PM   #7
Aqualynx
The coolant the car use is light pink in color and I used a flashlight while checking both day and night. The coolant is between full and low. A day before I asked the question, I went to the dealer to buy a coolant and the employee there said that it should be light pink and that I should have it flushed and filled with the coolant I bought but... I thought it was too early for that since it’s only been 5 months. So I went here to ask. I will do the things you guys suggested.
Old 08-23-2018, 11:50 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
You used the wrong stuff.
Drain.
Flush until clear.
Refill with the correct blue stuff.
kch (08-24-2018), Teseo (11-30-2018)
Old 08-24-2018, 04:00 AM   #9
highway7
Drives: FRS 2013
Because you are in the Philippines things might be different for you; however in Canada and the USA ALL Toyota 86 / FRS / BRZ uses the dark blue/turquoise blue Subaru coolant, or "Scion blue" / "Toyota Blue" coolant (That is only used by the FRS, because Scion TC, iM, xB, etc uses Toyota pink coolant). Yes, even the "Toyota" 86 uses blue Subaru coolant and NOT the pink coolant that every other Toyota uses, I was just at the dealership today and a new 86 had blue coolant in the overflow reservoir.
I'm thinking someone accidentally put Toyota pink into your car and it mixed with the blue, making it black.
highway7 is offline   Reply With Quote
Old 08-24-2018, 05:09 AM   #10
Aqualynx
Thank you. I will get the blue coolant you’re talking about at the Subaru dealership and have my 86 flushed and filled with the blue one. I’ll also talk about it at the Toyota dealership where I got it.
Old 08-24-2018, 02:50 PM   #11
highway7
Drives: FRS 2013
This car is known for disappearing coolant especially when the car is new. Factory fill is typically halfway between max and min at cold. My guess is the coolant level was low after a bit of driving, you brought your car in for service, they saw the coolant was low, and topped it off with the pink toyota coolant literally every other Toyota uses. The subaru coolant is already very dark to begin with, the pink must mixed made it near black.
As well, every FRS/BRZ/86 is made in the same factory in Japan. I'm very confident this is what happened and even for a hot country like the Philippines, it still uses the same "blue" coolant as the ones sold in North America, but you can always read the manual to make sure.
EDIT: I just read the Australian 86 owners manual and it also calls for Toyota Blue. Yes, the person at the dealership MESSED UP by telling you it needed pink coolant.
The Following 2 Users Say Thank You to highway7 For This Useful Post:
Aqualynx (11-22-2018), Tristor (08-24-2018)
Old 08-24-2018, 02:59 PM   #12
Brink
Drives: 2017 BRZ
Looks like another case of a dealership being clueless about this platform.
Brink is offline   Reply With Quote
Old 08-25-2018, 09:17 PM   #13
Aqualynx
Thank you so much... Blue coolant it is.
Old 08-25-2018, 11:10 PM   #14
86MLR
86MLR's Avatar
Ah, stealer, I mean dealership monkeys strike again, here is my oil filter after the first attempt at removal, ham fisted greasers strike again, the old hammer and screwdriver managed to get it off.
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 01:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 08:37 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Black Flakes in Coolant Reservoir?? John Rambo Issues | Warranty | Recalls / TSB 7 07-15-2015 05:58 PM
Color code for TRD matte black cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 13 06-24-2013 08:20 PM
