Old 08-22-2018, 10:41 PM   #1
jRuN
OFT v4.03 Tune Question (Going to Dyno)
As i'm aware, the v4 tune starts the IAM at .7 and over time, it will supposedly work it's way up to 1 if you are using premium fuel.
Question: If i am going to the dyno, when they start the car and do the pulls, it will be at .7, without a doubt, as i've noticed it takes a little bit of street driving before it starts working it's way up. Will this mean non-optimal performance while doing the dyno pulls with it being at .7 ?
Or does it really not make that much of a difference?
Follow up question. If i know i'm going to use 93 octane, would it make more sense to download the 93 octane tune from the master list on the OFT website and run that instead of the new v4 tune that was meant to be a one-size fits all?
jRuN is offline   Reply With Quote
Old 08-22-2018, 10:46 PM   #2
vtekdis
Drives: 2013 BRZ Premium
If you feel like the 93 is knock free on that map change the IAM to 1.0 Problem solved.
Sent from my SM-G955U1 using Tapatalk
vtekdis is offline   Reply With Quote
The Following User Says Thank You to vtekdis For This Useful Post:
wparsons (08-23-2018)
Old 08-22-2018, 10:57 PM   #3
jRuN
Excellent point!
Now I just gotta uninstall my 64bit Java and install 32bit Java in my windows box so that I can use RomRaider....
... Unless someone knows a better way around that issue?
Sent from my Pixel XL using Tapatalk
Old 08-23-2018, 07:40 AM   #4
freerunner
freerunner's Avatar
Drives: GT86
Excellent point!
RomRaider runs fine despite the alert message on 64 bit on my machine(s). At least if you can do without 3D visualization of the tables.
freerunner is offline   Reply With Quote
Old 08-23-2018, 12:06 PM   #5
jRuN
Problem is i can't get it to install. I imagine i need to back the java down to 32bit, run the installer.. and then perhaps i can go back to 64bit and run it as you suggest.
Old 08-23-2018, 12:52 PM   #6
Viper8
Drives: Scion FRS
I had to do the same thing. Installing the 32bit fixed all my problems.
Viper8 is offline   Reply With Quote
Driving to a dyno tune: Question xsnapshot Scion FR-S / Toyota 86 GT86 General Forum 4 04-14-2016 10:53 PM
What a dyno tune can do for you. jonbonazza Software Tuning 9 03-15-2015 12:53 AM
Need ecutek to dyno tune? HGaudio Software Tuning 6 02-18-2015 01:36 PM
My Dyno Tune Results brz961 Software Tuning 3 08-29-2014 12:43 AM
Dyno tune near CNJ? Craig NY / NJ / CT / PA 2 01-31-2013 07:57 AM
