Old 08-18-2018, 12:23 AM   #1
Scir16v
Drives: 240sx, 2013 frs
Bypass fuel computer???
Is there a way to run the fuel pump without needing techstream to run the fuel pump? Such as by jumping a relay?
I have this flood car that I’m working on and I want to drain the fuel tank. As in the manual, there is a special tool to connect to the fuel lines that costs over $300, but I can get around that part. I haven’t been able to find a way to energize the fuel pump. I’ve looked through a bunch of posts here and haven’t found a definitive answer.
Scir16v is offline   Reply With Quote
Old 08-18-2018, 05:10 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Open this wiring diagram in another tab and drill down to the pump via System Circuit > Engine / Hybrid System > Engine Control > Fuel Pump Control ECU Assembly / G12
Do you have a multimeter and two safety pins? I've never verified that it's just 12 volts there so I can only advise you on how to do that for yourself. It most likely is, but I never assume unless I can get eyes on a physical relay.
Cusco transmission mount collar kit, Verus fuel rail / computer bracket Summerwolf Transmission and Driveline 4 12-10-2019 08:16 AM
BRZ Nav Bypass lxsedan CANADA 43 03-30-2015 07:44 AM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
Computer Help kanundrum Mid-Atlantic 10 01-12-2013 03:26 AM
Computer for my Frs help Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 22 09-28-2012 04:51 PM
