Old 08-17-2018, 06:45 PM   #1
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
NRG Carbon Fiber Bucket seats install journey light weight
Just got my NRG Carbon Fiber seats in and installed today. RSC-310 Medium
I used VAC motorsports stationary mount on the driver side.
Circuit Sports Sliding mount (like Buddy CLub) on the passenger (GOT REAL CHEAP)
Nice seats Carbon fiber weave looks great but mainly bought these for weight Reduction. These aren't full carbon fiber to my disappointment, underneath the cushions you can see the fiberglass used for the shell, only the outer shell is carbon fiber. Similar to how a lot of the CF hoods are made that aren't dry carbon.
Once installed they are plenty Sturdy. Only reviews I could see were from 10 years ago so I took a gamble on these but so far am impressed for the pair shipped with side mounts $800
Weights:
NRG Seats 14lbs each x2
VAC motorsports mount with side aluminum legs = 8.25lbs
Circuit sports mounts 8.75lbs
Mounts that came with seats Heavy (NOT USED) = ~4.5lbs each
Stock 17' Driver seat = 42.75
Stock 17' Passenger Seat = 38.75
TOTAL WEIGHT LOSS TODAY = 36.5lbs!!!!!!!!!!!!!!
Removing the Stock seats was FUCKING ridiculous. They upgraded from a torx bolt to a 12mm hex bolt and it was still stuck not moving and starting to strip
No drilling, cutting or other methods others have used went straight to the torch!!
Burned a little carpet but only 10 seconds of heat and the bolts turned easily.
Stripped bolt out
VAC mounts bolted up easy, many holes to choose from to get proper mount fairly easy
Circuit Sports being sliding and more complex took some trials to get right. Only had to cut one part of side mount to fit over locking handle. I really didn't have to cut that much
Finally got how I wanted
Weights:
Buddy Club sliders and side mounts 8.75lbs
VAC motorsports mounts and ALuminum side mounts 8.25lbs
NRG Bucket
STock Driver
Stock passenger
FINALLLLLY INSTALLED
SuperTom is offline   Reply With Quote
Old 08-17-2018, 07:58 PM   #2
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Nice! How’s the comfort of them?
Drambeenie is offline   Reply With Quote
Old 08-18-2018, 10:01 AM   #3
SuperTom
SuperTom's Avatar
So far so good Not as comfortable as stock but comfy for buckets. Real test will be when I go back to work Monday 100mile commute. I like the side bolsters aren't too high so its easy to get in and out. A good compromise if you drive on the street.
I also like each individual cushion is sealed with Velcro. Meaning I can open up each cushion and add in a little more foam or change out the foam to different densities.
Old 08-18-2018, 10:54 AM   #4
StraightOuttaCanadaEh
Wes
Definitely get back to us re: comfort after the work commute. Super interested to find out. Do they slide back and forth?
Instagram: @gt86ws
Old 08-18-2018, 02:37 PM   #5
SuperTom
SuperTom's Avatar
It depends what mounts you use. The VAC mounts I used on the driver side are stationary. Once I'm set I'm not moving anyway. Plus a good excuse so crazy friends cant drive it now
Passenger side I used Buddy Club which slide front and back. Weight is the same for both the buddy club were a bit harder to install.
Old 08-20-2018, 10:33 AM   #6
SuperTom
SuperTom's Avatar
Just an update on the comfort level. The stock seats during my commute my bottom tailbone area would get sore. That was not the case today.
-The center lower back area on the NRGs is somewhat hard. But I like it as my posture more upright compared to stock. Maybe why my tailbone isn't sore since my posture is better with these.
I usually push that area towards my lower back on cars that have that adjustment.
-The reviews from 10 years ago said these seats flex. They don't flex with me intentionally pushing back into them. Plus they were 12 or 13lbs, I got 14 lbs maybe they added in a 1lb of fiberglass to stiffen them. Im 5'9" 175 so maybe someone large could make them flex.
-Much happier with the results than expected for $800 for the pair shipped!
Old 08-20-2018, 01:28 PM   #7
Greacemonkey
Drives: dark grey Scion frs 2013
Nice, 36.5 lbs is a nice weight shave! how is the center of gravity, do you sit lower in the car?
Greacemonkey is offline   Reply With Quote
Old 08-20-2018, 01:49 PM   #8
SuperTom
SuperTom's Avatar
I did lower it a notch since that install pic. Im 5'9" So I don't like to sit too low and not be able to see over the dash. I think im going to keep the seat itself low but add a layer of memory foam on the butt cushion to raise me back up an inch
Old 10-09-2018, 07:27 PM   #9
arkanist
Drives: 2016 BRZ Limited, Stock
Do you have an estimate of how much lower you are now than in the stock seats? I need some extra room to clear a helmet comfortably and these look like a nice option.
arkanist is offline   Reply With Quote
Old 10-09-2018, 08:47 PM   #10
SuperTom
SuperTom's Avatar
Well again im not that tall I set it to around the same setting I had with the stock seats. But there is more holes to got another inch lower.
The VAC fixed mounts will give you the ability to go lower as opposed to the buddy clubs, but you lose the sliding ability. No big deal if you are setting up the car for yourself
Old 10-09-2018, 09:50 PM   #11
Impureclient
Drives: 2015 FR-S
What is the running total on how much you've decreased the weight from stock?
Impureclient is offline   Reply With Quote
Old 10-09-2018, 10:27 PM   #12
SuperTom
SuperTom's Avatar
-334.25 lbs
Still have dry seibon Carbon doors to install. If the internet is right and the windowless stock doors weight 50lbs, I should lose another ~80lbs from the doors
Old 01-26-2019, 11:15 AM   #13
q335r49
Drives: 2013 scion fr-s
Nice setup. Is the backseat still usable by an adult? I know that when I access the back seats I usually have to slide the seat foward and fold down the seats.
q335r49 is offline   Reply With Quote
Old 01-28-2019, 02:53 PM   #14
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
$800 for two seats it's quite the bargain. How durable are they in the event you have an accident? From what I gather the cheaper seats don't hold up compared to the likes of Recaro and Sparco.
nastynate88 is offline   Reply With Quote
Seibon Carbon Fiber OEM Hood Install w/ Weight Comparison and PICS! TyperRspec789 Cosmetic Modification (Interior/Exterior/Lighting) 23 02-12-2023 05:15 AM
carbon fiber hood vs carbon fiber trunk which saves more weight? stlgrym3 Cosmetic Modification (Interior/Exterior/Lighting) 43 09-05-2020 05:46 PM
Cusco x Bride - Interior Carbon Fiber, Bucket Seats & more from 86Insider.com 86_Insider Interior Parts (Incl. Lighting) 6 09-03-2013 05:52 PM
NY: Status Ring carbon fiber bucket seat leather Migs. Interior Parts (Incl. Lighting) 5 08-01-2013 09:42 AM
New 2x Carbon Fiber Bucket Seats - RSC300 phatpanda Interior Parts (Incl. Lighting) 25 05-11-2013 11:59 AM
