Old 08-16-2018, 06:19 PM   #1
mrg666
pessimistic skeptic
mrg666's Avatar
Difference between WRX and FRS/BRZ brake pads
I have installed a WRX pad. And it works just fine. But it is missing the spring shown with red arrow. Do you know what is the function of it?
Replaced brake pads with Hawk Ceramic Performance. I noticed when installing that the front pads were HB432Z.661 instead of HB711Z.661. The one I have was exactly the same dimensions with the other but it was missing that little spring above.
Still worked just fine. So, whatever, I am not returning it. Any comments?
Old 08-16-2018, 09:36 PM   #2
wparsons
wparsons's Avatar
Most aftermarket pads won't have that anyway. It's to try to keep the pad quieter.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
mrg666 (08-16-2018), Strife26 (08-16-2018)
Old 08-16-2018, 10:00 PM   #3
mrg666
pessimistic skeptic
mrg666's Avatar
Thank you! I don't hear any noise yet. Maybe it is not that necessary.
The Following User Says Thank You to mrg666 For This Useful Post:
wparsons (08-17-2018)
Old 08-17-2018, 11:20 AM   #4
wparsons
wparsons's Avatar
Yeah, you'll be fine.
flickr
mrg666 (08-18-2018), Strife26 (08-17-2018)
Old 08-17-2018, 12:35 PM   #5
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
The spring clip is there to push the pad away from the surface of the rotor so it doesn't drag when the pedal is not pressed.
thatfilipinoguy is offline   Reply With Quote
The Following User Says Thank You to thatfilipinoguy For This Useful Post:
Old 08-17-2018, 01:29 PM   #6
wparsons
wparsons's Avatar
The spring clip is way too weak to actually move the pad...
flickr
Old 08-17-2018, 02:06 PM   #7
SpartaEvolution
SpartaEvolution's Avatar
Drives: NSX, G35, E36 328i racecar
It's actually a part of the pad wear sensor. You're fine if your new pads don't have it.
SpartaEvolution is offline   Reply With Quote
The Following 2 Users Say Thank You to SpartaEvolution For This Useful Post:
mrg666 (08-17-2018), Strife26 (08-17-2018)
Old 08-18-2018, 09:52 PM   #8
wparsons
wparsons's Avatar
We don't have pad wear sensors...
flickr
The Following User Says Thank You to wparsons For This Useful Post:
mrg666 (08-18-2018)
Old 08-18-2018, 10:12 PM   #9
It does, however, physically drag on the rotor and make noise, indicating to the driver that the brake pads are low. At least in theory.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
mrg666 (08-18-2018), strat61caster (08-19-2018), wparsons (08-19-2018)
Old 08-18-2018, 10:21 PM   #10
mrg666
pessimistic skeptic
mrg666's Avatar
Thanks everyone! Well, I sensed my brakes were getting worn-out before they started making noises. I don't need the indicators. The brakes are so much better now that I replaced.
Old 08-27-2018, 01:24 AM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You already have the answer but the technical name is "wear indicator"
When it gets to a lower thickness you get that classic high pitch squeal, which gives you enough time to replace it before rotor damage is done.
If you don't have it and are totally inept (which no one here is) the only squeal would be either an aggressive pad when cold or way later in it's life something rubbing right against the rotor like the rivets on the pad or the like. At that point you've probably damaged the rotor.
If you're smart enough to replace the pads yourself like everyone in this thread is, you probably don't need the wear indicator because you can feel the pads loosing effectiveness and know when to check the pad wear
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
mrg666 (10-17-2018)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
