Drives: car
Which transmission mount kit to get?
Took my car into a shop today to see what they could do about some drivetrain flex in my near 100k car. The shop owner recommended we start with a transmission mount job first and go from there.
I'm going over a couple options and not sure which one to go with. There's the perrin mount which looks like it inserts through and over the mount, and then there's the whiteline insert. Both can be installed at the same time apparently. So which one to go with, either one or both? Or would it be better to get an STi mount? |
Drives: 2014 Subaru Forester
The whiteline insert is a popular choice that doesn't cost too much.
The STi combo of engine/transmission mounts significantly reduce driveline slop without adding to NVH. I had them on my previous WRX and was so impressed that I added them to my BRZ within the first month of ownership. |
Drives: 2017 toyota 86
I have the sti engine mounts, white line trans insert, and white line diff inserts. Car feels tighter, more responsive, and no noticeable NVH.
Drives: 2018 BRZ tS
I have the whiteline and Perrin mounts installed together. NVH increased slightly but it is worth it for me. I recommend it and super easy to install.
Sent from my SM-G965U using Tapatalk
Drives: car
Good stuff thank you for replies. I ordered a perrin and whiteline bushing combo (the perrin shift stop apparently, not the mount kit).
I might consider upgrading to STi mounts on my planned 120k mile maintenance. |
Do you know if this
https://www.perrin.com/shop/drivetra...-mount-support can be fitted to STi transmission mount and if it worth? Thanks... |
#7 | |
Drives: 2014 BRZ Sport Tech
| Help needed. Please check my transmission mount. | Tor | Engine, Exhaust, Transmission | 21 | 11-12-2016 12:30 PM |
| STI transmission mount | jah29 | Transmission and Driveline | 1 | 03-14-2014 09:07 PM |
| Transmission rear mount | Nitro_FRS | Engine, Exhaust, Transmission | 2 | 12-30-2013 11:49 PM |
| Transmission mount question | Bullnettles | Engine, Exhaust, Transmission | 2 | 05-28-2013 12:22 PM |
| New cusco transmission mount! | Silverdub | Engine, Exhaust, Transmission | 5 | 07-11-2012 08:50 AM |
