Old 08-13-2018, 12:04 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
ACE 350 header running cooler
Had my ACE 350 header installed last week, still working on the tune revisions but I do notice the engine and oil temperatures are cooler than with Tomei header. I guess this is a good thing right?
stlgrym3 is offline   Reply With Quote
Old 08-13-2018, 12:32 PM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Because the ace headers are already coated?😒😒😒🤔🤔🤔
Dr. BRZ is offline   Reply With Quote
Old 08-13-2018, 12:41 PM   #3
stlgrym3
Yes it is ceramic coated, but my Tomei header was thermo wrapped as well.
Old 08-13-2018, 12:48 PM   #4
wparsons
wparsons's Avatar
I bet the coolant temperature is in your head, unless you were overheating before the thermostat in the cooling system regulates temperature really well.
Unless you were heat soaking the oil pan with the old header, I doubt it's actually directly caused by the header swap either.
flickr
Old 08-13-2018, 12:59 PM   #5
stlgrym3
No it wasn’t overheating before. Before, the temp was at the midway level, now with the new header after same amount of driving, the temp needle is at the 1/3 mark.
Old 08-13-2018, 01:30 PM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Better to check your thermostat.
Old 08-13-2018, 02:37 PM   #7
jflogerzi
jflogerzi's Avatar
Its the difference between wrap vs coated. Nothing else
2013 Series 10 FRS #553
Old 08-13-2018, 08:19 PM   #8
wparsons
wparsons's Avatar
It's in your head, or the driving conditions are different. There's simply no way that in normal driving the old header was heat soaking the whole engine so badly that the new one is making the gauge show a different reading.
flickr
Old 08-13-2018, 09:16 PM   #9
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
ive daily driven with and without ace and opened the hood before and it still is like an inferno in there
Breadman is offline   Reply With Quote
Old 08-14-2018, 12:28 AM   #10
steve99
As the other guys said if your coolant temp guage is now only getting to 1/3 of dial instead of 1/2 you have problem with thermostat guage or coolant level.
the standard gauge is set up to read 1/2 scale at about 90-95C which is normal coolant operating temp.
If its only getting to 1/3 max then likely you have some issue, log the actual coolant temp in degrees using your ecutek cable
Old 08-14-2018, 12:37 AM   #11
stlgrym3
I need to pay more detail attention on the temperature fluctuations. The 1/3 vs 1/2 was my general impression after the ACE header and Delicious Tune. But sometimes when the car is parked with engine running, the thermostat does creep up to the halfway mark. But when the car starts moving, it’ll dip below the 1/2 mark. While driving it’s generally between 1/3 and 1/2.
I did check the log I just sent to Delicious Tuning, during the 3rd gear moving log, the coolant temp were between 87-89 degrees, and oil temp were between 97-98 degrees. This log was taken after the car been idled for 15 minutes from a cold start while collecting another set of logs.
Old 08-14-2018, 01:00 AM   #12
steve99
most cars the temp guage will just sit at 1/2 once warmed up, the thermostat n combination with electric fans will keep coolant around the 90 degree mark, if you see it dipping much below 90 or so you probably got thermostat issues unless you have changed to lower temp thermostat
Old 08-14-2018, 01:02 AM   #13
steve99
Its possible to recalibrate the coolant tmep sensor in btune tables but its not something normally needed or normally done
Old 08-14-2018, 01:15 AM   #14
stlgrym3
Why the thermostats all of sudden having problem? Is this because of the header install? According to the log I’m couple degrees below the normal point, will this cause any harm on my car?
What header are you running/ supercharged fa20's only Epic_integra Engine, Exhaust, Transmission 15 03-30-2019 01:57 AM
Pa FRS/BRZ guys, running a catted header HotlavaFRSGT86 NY / NJ / CT / PA 6 02-24-2017 01:17 PM
Mishimoto Oil Cooler - Anyone running one? swift996 Engine, Exhaust, Transmission 34 05-28-2014 10:07 AM
What Oil Cooler and Radiator you running? Ny Brz Forced Induction 24 08-13-2013 10:04 PM
Anyone running 3" exhaust & catless header? RiskyTrousers Engine, Exhaust, Transmission 19 08-01-2013 09:09 AM
