Old 08-13-2018, 11:15 AM   #1
StraightOuttaCanadaEh
Wes
Shifter rattle gone after bushings/springs but now back again?
As the title states, a few weeks back I installed the perrin/whiteline bushing combo, mtec springs and diff bushings as well. The best part was that the shifter rattle was gone at WOT. Now, I'm guessing everything has broken in nicely, softened up a tad and the rattle is back. Granted, it's not as irritating as before, but still irritating. Anyone else gone through the same recurrence? What did you do to fix it?
Instagram: @gt86ws
Old 09-23-2018, 03:17 PM   #2
bhmax
Drives: 13 BRZ, 17 Focus RS
I don’t know that I’ve had it come and go like that. I do have a bit of high rpm rattle that I’m hoping to get rid of on my STI shifter. I’ve seen recently where an aftermarket reverse lockout lever can help get rid of it. I’m thinking about trying out the Raceseng version soon.
bhmax is offline   Reply With Quote
Old 09-23-2018, 05:55 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Gotta get up in between the gearshift tube and the cable with some foam rubber or something that survives lockout usage.
[ame]https://www.youtube.com/watch?v=TMaI-qp3lKY[/ame]
Old 09-23-2018, 06:16 PM   #4
Ultramaroon
not playing cards
It might also be a candidate for damping grease. I've played with their cleanroom products and could see trying PG-44A in this case.
...or 767A
https://www.amazon.com/Lubricant-Gre.../dp/B00W6KWK1Y
Old 09-23-2018, 10:17 PM   #5
radroach
Drives: car
@StraightOuttaCanadaEh same thing happened to my car. At least, a lot less rattle after bushings combo install.
Old 09-23-2018, 10:42 PM   #6
Wes
Yeah definitely less bit still noticeable. I did some more research and apparently trd short shift kit eliminates it completely.
Instagram: @gt86ws
Old 09-24-2018, 01:03 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC there were two TRD short shifter kits, JDM & USDM ones, no? Is that attributable to both?
Old 09-24-2018, 02:02 AM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Looking at the review of this TRD quick shift it appears this one removed the rattle as well, and I'm assuming this is the USDM one:
http://www.ft86speedfactory.com/trd-...-kit-1465.html
The instructions look like the USDM instructions that came with my TRD intake and were clearly typed out on the bottom that it was produced in california or texas or somewhere like that.
Old 09-24-2018, 07:24 AM   #9
Wes
Yep that's the one
Instagram: @gt86ws
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
Shifter springs/bushings/shifter performance Darnold Engine, Exhaust, Transmission 10 10-22-2014 11:49 PM
Short shifter, bushings, springs etc. - Does anybody have these? daiheadjai CANADA 8 05-05-2014 10:08 PM
BRZ Shifter Rattle TSB sc0urge BRZ First-Gen (2012+) — General Topics 2 08-26-2013 08:53 PM
Replace shifter bushings? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2013 10:49 AM
