Old 08-11-2018, 02:49 PM   #1
brayshakes
Drives: 2018 GT86
Experience with TRD springs?
I saw that toyota offers trd springs that cut about an inch off ride height. I was curious about other users experience with these springs? I daily drive the car so anyone with a similar user profile would be helpful.
Braden.
Sent from my SAMSUNG-SM-G930A using Tapatalk
"Do you fit in that?" (Everyone).
brayshakes is offline   Reply With Quote
Old 08-11-2018, 04:20 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Braden.
Hope this helps
The Following User Says Thank You to x808drifter For This Useful Post:
Leonardo (08-12-2018)
Old 08-11-2018, 05:08 PM   #3
MrClean614
Drives: 981 Boxster, ‘24 Emira
I’d be interested to know if the TRD spring rates match up well to the dampening of the BRZ PP shocks?
TIA
MrClean614 is offline   Reply With Quote
Old 08-11-2018, 05:49 PM   #4
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Braden.
I have the TRD springs on my 2017. DD and couple of trackdays. It is stiffer compared to the kouki oem ride, so it will be a bit bouncy but not too much. Almost like the zenki ride, which is more stiffer than the kouki oem ride. It's ok for DD, but just a bit soft for the track even with trd sway bars.
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 08-11-2018, 07:13 PM   #5
stevesnj
stevesnj's Avatar
Love my TRD springs. Perfect for DD and much better than stick for those few yearly track days. Handling is very noticeable and ride is better than stock springs IMHO.
My 2016 Build thread
The Following 3 Users Say Thank You to stevesnj For This Useful Post:
BAD ROD (08-12-2018), LancePower (08-12-2018), Yoshoobaroo (08-12-2018)
Old 08-12-2018, 03:55 AM   #6
gpvecchi
gpvecchi's Avatar
US TRD springs are Eibach Pro kit.
gpvecchi is offline   Reply With Quote
The Following User Says Thank You to gpvecchi For This Useful Post:
Old 08-12-2018, 07:13 AM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Can you elaborate on ride is better than stock? The springs are significantly stiffer, so it can't be actually 'comfier' which usually means softer. Rears are 37% stiffer, fronts are 56% stiffer.
Old 08-12-2018, 01:26 PM   #8
MrClean614
Originally Posted by Yoshoobaroo View Post
The springs are significantly stiffer... Rears are 37% stiffer, fronts are 56% stiffer.
Good information, thanks.
Old 08-12-2018, 01:29 PM   #9
MrClean614
Thought this was the case but the specified drops from Eibach didn’t exactly match what the TRD specs say.
Old 08-12-2018, 02:46 PM   #10
gpvecchi
gpvecchi's Avatar
Check that there are 2 different part numbers for Eibachs, one for EU and one for US...
Old 08-12-2018, 03:11 PM   #11
Yoshoobaroo
TRACKBREAD
http://www.ft86club.com/forums/showthread.php?t=8739
Old 08-12-2018, 03:14 PM   #12
Yoshoobaroo
TRACKBREAD
I thought the ~1" drop fit eibach pro kits was a generic number for most cars? Like if you have a mustang vs a BMW vs a Subaru it can vary +/- 1/4" depending on what kind of spring rate setup eibach decided to go with for your car model.
Old 08-12-2018, 03:44 PM   #13
MrClean614
Nice, thanks for the link!
Looks like the drop and spring rates of the Eibach Pro-Kit would work just fine with the Sachs shocks for street use. Although Boudin* just warned me about the lack of travel with the factory shocks. Hmm ��
*http://www.ft86club.com/forums/showp...34&postcount=3
Old 08-12-2018, 10:26 PM   #14
stevesnj
stevesnj's Avatar
The ride was more comfortable even though the springs are stiffer, hard to explain but that's what I noticed.
The Following User Says Thank You to stevesnj For This Useful Post:
Yoshoobaroo (08-13-2018)
Review: Swift Sport Springs vs RCE Yellow springs on B6 Shocks EGOBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-15-2018 08:21 PM
Widest wheels without rubbing on stock springs with eibach springs ? H214M Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-09-2017 11:41 AM
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs leunglambs NY / NJ / CT / PA 3 06-09-2017 02:49 PM
Any experience with shifter springs? edocura Engine, Exhaust, Transmission 7 08-28-2015 01:55 PM
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 03:18 PM
