Old 08-09-2018, 08:18 PM   #1
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
TRD PERFORMANCE AIR Intake. Only 2 HP improvement.
http://dsportmag.com/the-tech/scion-...ogramed-ecu/8/
According to their testing, there was only .5 HP increase. Did Toyota Lie on their web store saying "Dyno-tested and designed to deliver an increase in both horsepower and torque for superior acceleration "
How much superior is .5HP on the acceleration?
pcguru2000 is offline   Reply With Quote
Old 08-09-2018, 08:41 PM   #2
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
article says 2.5 hp Gain? You still need some tuning to make the most out of it but don't expect much
SuperTom is offline   Reply With Quote
Old 08-09-2018, 08:42 PM   #3
StraightOuttaCanadaEh
Wes
Looks like about 4 hp at 6500-7000 rpm. They do also say it requires an ECU reflash to optimize gains (if any). So a tune I guess
Instagram: @gt86ws
Old 08-09-2018, 09:18 PM   #4
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
everything requires a tune to actually work on this car, but 4 hp at the top end without a tune is pretty darn good.
Old 08-09-2018, 11:53 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I had the stage 1 oft tune with the TRD and the stock, the maf scaling required was nearly the same as stock after datalogging. It definitely lowered intake temps slightly and added more intake growl, but I'm pretty sure a drop in may have had similiar gains, or the grimspeed CAI which supposedly performs way better.
Also the only reason I got it was because I knew someone in a Toyota parts department and really wanted to get rid of the sound tube well before I got a header.
Old 08-10-2018, 08:16 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I can honestly say I didn't notice a huge difference. The car does sound better, and it cleaned up the engine bay. I like the reusable filter and factory fitment.
Paired with the hks snorkel it DOES seem to be a little better when you're winding it out, but like most intakes it isn't a great bang for the buck modification. At least this one isn't an issue while you're under warranty and it looks great while having a lifelong use filter.
Old 08-10-2018, 10:40 AM   #7
cheeseburger
IG: @_southwell_86
cheeseburger's Avatar
Drives: Rwd Prius.
Lol what did you expect
2013 frs
I 🖤 drifting.
https://youtu.be/XW5XBQuLDUM
IG: @_southwell_86
cheeseburger is offline   Reply With Quote
Old 08-10-2018, 10:52 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
So, not everything.
Old 08-10-2018, 11:20 AM   #9
tomm.brz
Drives: brz 2017 hksv2
It gives a bump in power because it leans out the afr ,like most panel filters do
Old 08-10-2018, 01:02 PM   #10
why?
why?'s Avatar
Drives: series.blue
Originally Posted by nikitopo View Post
So, not everything.
it probably does much much better with a tune.
Old 08-10-2018, 01:12 PM   #11
tomm.brz
When you tune it you LL fine out that it lets enter few more air compared to the stock..a bit more yes mostly because of the restrictive stock snorkel, but it is a NA and stock filter is not globally so restrictve so you gain mostly from the tune itself than from the intake..so actually you GEt relatively more gains from the intake without a tune
Old 08-10-2018, 01:42 PM   #12
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Did they apply the "TRD" sticker? Everyone knows that is the TRUE source for horsepower gains...
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 08-10-2018, 02:21 PM   #13
pcguru2000
pcguru2000's Avatar
I'll just get a 100 stickers to go 0-60 in 1.2 seconds.
Old 08-10-2018, 03:15 PM   #14
re-animator
according to DSportmag's dyno runs it had a very very close AFR to the stock intake. The design is very similar to the stock intake, just that the intake box is bigger and thus greater surface area for the filter, which delivers more air to the engine. All cold air intakes for this car work roughly the same, with the exception of maybe the grimmspeed. The TRD box uses a panel filter which does not have as great of a surface area as cone filters like the K&N typhoon. The K&N for example delivers even more air than the TRD, but as a result, it leans out the mixture (duh, more air and the same amount of fuel = greater AFR). The grimmspeed is also a cone filter, but puts the MAF sensor directly inside the airbox so that the engine computer can give you more fuel to go along with the increase in air. AFAIK, the airaid, injen, and skunk2 intakes are all designed this way, but grimmspeed did the most testing for our specific platform.
re-animator is offline   Reply With Quote
TRD Performance intake Bpatti204 Engine, Exhaust, Bolt-Ons 0 09-23-2017 04:55 PM
'14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube SoCalArgento Engine, Exhaust, Bolt-Ons 4 02-06-2015 10:40 PM
Power Improvement on the BRZ qbzee007 AFRICA 51 06-12-2014 03:10 PM
WP8 GDR3 improvement for FR-S 2014 HU oldpueblo Electronics | Audio | NAV | Infotainment 0 10-14-2013 07:22 PM
light steering angle improvement alexmotrix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-17-2013 02:38 AM
