Drives: 2017 Subaru BRZ Limited PP
Oil drain valve recs
I'm considering putting in an oil drain valve to make life easier. Curious:
1) For those using Fumoto - any long term issues with leaks? Ground clearance? (I'm stock height) 2) Anyone using or have opinions on any others? (EZ Oil, Femco, NoSpill, Stahlbus) Thanks! |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Fumoto here.
Changed the oil again last week. No leaks. It's above the under fairing. Can drain directly into old empty 1gal jugs. No oil drainpan cleanup. Shweet!
"I gotta rock." -- Charley Brown |
The Dictater
Drives: '13 Red Scion FRS
I also have a Fumoto. If you go with that, make sure you get the part with the shorter nipple.
No leaks for me, and I remember laughing maniacally at how easy it makes oil changes the first time I used it. If you do your own work I highly recommend it. I also got the little plastic locking clip for added peace of mind, though it's not really necessary. |
Certified Wumbologist
Drives: 2015 Scion FR-S
I too have a Fumoto valve with the little clip to also give me reassurance that it won't open on its own.
Had it for about a year and a half with no issues so far. I'm on coilovers with a mild drop and have no issues with ground clearance. Highly recommend! |
Wheels for Brains
I use the Fumoto valve with clip. Tracked and daily it. Seems to work fine. No leaks or issues.
I'm lowered about 1.5" (moderate). The metal engine tray sits lower than the lowest point of the valve, so that helps protect the area. |
520
Drives: Series 10 Fr-s #520
I use Fumoto on all my vehicles. Never had a leak or any problems. I've had one on my Sequoia for 13 years.
Drives: 2016 Subaru BRZ
I've had a Fumoto valve on my BRZ for almost 3 years now, no issues.
Undisputed El Presidente
Drives: Zenki 37J ZN6
I've had the Fumoto for a couple years. Just get the one with no nipple or the short nipple.
Mine has even take a hit from a decent piece of debris (it dented the metal skid plate) and still no leaks. |
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
if you live in an apartment or don't want to ever get under the car you can just use an oil drain pump. Put a tube down the dip stick hole and pump a few times and all the oil gets siphoned out. No jacks, never have to remove the oem oil drain plug, no getting on the ground, and can be done when the engine is hot.
Something similar to this. Just throwing out an alternative. :-) https://www.amazon.com/Mityvac-7201-...words=oil+pump |
#10 |
6 years and 70K+ miles on my Fumoto valve.
No nipple, no clip. I travel on dirt roads and gravel in rural areas too (stock height). No problems so far. |
#11 |
Drives: car
@TachyonBomb until somebody makes a video of them doing a topside oil change successfully on their 86, I'm going to wait. I don't want to be the guy to report getting the tube stuck in the dipstick hole.
I have a fumoto valve and its nice. I checked it this morning and it was dirty but didn't seem like any oil has seeped from the drain hole. Last edited by radroach; 08-22-2018 at 06:33 PM. |
#12 | |
#13 |
The Gunshine State
Drives: '14 BRZ Limited
Another vote for Fumoto, I've had mine for almost a year and love it.
![]() Current DD: M235i |
#14 |
Drives: car
@gravitylover which specific brand pump did you try (and fail) with?
Some guy was all over my car the other day telling me I needed to do a topside change. On other cars maybe, I explained, but on subarus the dipstick is too narrow
| First Oil Change, Fumoto Oil Drain Valve | oldnotdead | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 29 | 07-23-2021 12:39 PM |
| FS: Fumoto Drain Valve | turbos86 | Engine, Exhaust, Bolt-Ons | 2 | 03-15-2017 06:41 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
| SOLD - Fumoto F108 Oil Drain Valve - NEW | ZZT86 | Australia Classifieds | 0 | 09-25-2015 05:03 AM |
| GROUP BUY: Fumoto Drain Valve | Simon99 | Mechanical Maintenance and Tools | 8 | 03-28-2014 06:27 PM |
