Old 08-04-2018, 10:46 AM   #1
mrg666
pessimistic skeptic
mrg666's Avatar
RR racing sport brake kit
I am about to order the following brake kits
https://www.rr-racing.com/RR-Racing-...gt86fbk005.htm
and
https://www.rr-racing.com/BRZ-and-FR...gt86rbk002.htm
My goal is better brake performance than the stock brakes and save some weight. I don't think I need those bigger 6 piston kits since I don't track my car. I am not going for looks, I am not even ordering the colored calipers. All I care is better brake performance but not more than I need.
Based on my googling, these brakes keep the original rear/front brake balance and provide better braking performance. And, the cost is not too high.
Am I missing anything? I would appreciate any other thoughts before I order them.
Old 08-04-2018, 10:58 AM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
What are you doing on the street where the stock brakes are failing?
churchx (08-04-2018), finch1750 (08-09-2018)
Old 08-04-2018, 11:26 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you want better performance then just throw different pads in the stock calipers and swap out the fluid. All BBK does is add more thermal mass to handle heat better and prevent fade and excessive wear.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
churchx (08-04-2018), fika84 (08-08-2018), kevaughan (04-12-2024), Sapphireho (08-04-2018)
Old 08-04-2018, 11:46 AM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
Yes, I know that stock brakes can be improved with better pads, rotors, brake fluid, and ss lines. So you are saying this brake kit will not be better than what I can get from the stock brakes with a routine brake service?
Old 08-04-2018, 11:55 AM   #5
mrg666
pessimistic skeptic
mrg666's Avatar
LOL, I won't bite it. Not in the mood today.
Old 08-04-2018, 11:56 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you are not tracking your car, no need.
Message CSG mike and let him know what you want and your application. He is really good about helping people select a product that would work.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
mrg666 (08-04-2018), Sapphireho (08-04-2018), stevesnj (08-04-2018)
Old 08-04-2018, 12:26 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Wasn't trying to start anything. What msg said.
mrg666 (08-04-2018)
Old 08-04-2018, 12:44 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
Okay, you guys saved me more than a grand. I will be ordering a brake service package from ft86sf instead. It was going to be more fun installing the BBK but this will also be fun. Yey, a couple hours of wrench time!
BTW, there is only one thing that can be done on the street: drive within legal limits. And this is what I am doing.
Old 08-04-2018, 12:52 PM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
My street brake setup.
DBA 4000 drilled and slotted rotors
DS2500 Ferodo brake pads
Perrin master cylinder brace
Mann Engineering Stainless Steel Brake Lines
Torco RT700 Brake Fluid
mrg666 (08-04-2018)
Old 08-04-2018, 01:08 PM   #10
stevesnj
stevesnj's Avatar
WinMax W2 on stock solid rotors with G-four brake fluid. DD and track work awesome
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
mrg666 (08-04-2018)
Old 08-07-2018, 07:10 PM   #11
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
and
I actually run Wilwood 6 Piston front and 4 Piston rear, drilled and slotted with the B10 pad. I would have to say yes, there is a difference between my StopTech pads and Centric blank rotors (stock calipers) from a pure street driving perspective.
First off, with the slotted rotors, you get a rumbling sensation in the brake pedal and even the whole entire car if you apply light brake pressure. It seems go away with more brake pressure.
The pedal travel is less to get the car to begin diving. I have to re-learn braking points and how much brake pressure to apply. More times than not, I come to a stop sooner than expected accidentally.
Also, psychologically I do feel more confident with the car because I felt stock brakes were under-boosted compared to like a Corolla or a Camry personally. I usually brake earlier with the stock brakes because they don't have that massive bite down that other overly boosted brakes are.
I don't think stopping distance decreased or increased, but with the torque these brakes deliver, it's feels confident inspiring. Also knowing that my brake distance will be repeatedly the same and it can take more abuse/heat, it psychologically helps me as well.
I'm pretty sure you won't be disappointed with the 4 Piston or 6 Piston. I think the red really pops with my Work Wheels
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
mrg666 (08-07-2018)
Old 08-08-2018, 12:27 PM   #12
fika84
fika84's Avatar
I too have Wilwood 6pot front and 4 pot rear with BP10 pads and I don't get rumbling... You might want to check that out.. just sayin!
fika84 is offline   Reply With Quote
Old 08-08-2018, 01:12 PM   #13
N1rve
N1rve's Avatar
How long have you had it? I think it's because mine is still pretty new.
N1rve
Old 08-08-2018, 01:39 PM   #14
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
@mrg66 I wouldn't have listened to everyone here. You are supercharged I would have went with the big brake kit. You are able to get to high speeds faster, meaning you need to stop faster + the extra weight on the nose
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
andrewFT86 (08-09-2018), mrg666 (08-15-2018)
RR-Racing Sport Performance and AP-Racing Essex Initial Comparison Gear_One_Performance Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 04-20-2016 04:31 PM
Brembo: GT, GT-R, Club Sport Brakes, AP Racing BBK & Agency Power Brake & Clutch Line eauto Brakes, Suspension, Chassis 361 10-15-2014 01:43 PM
H&R Sport & Super Sport Springs for FR-S / BRZ @ Guerilla Racing GuerillaRacing Brakes, Suspension, Chassis 5 01-11-2013 05:20 PM
Stoptech Sport Brake Kit goke186 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-28-2012 06:57 PM
