Old 08-03-2018, 01:04 PM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
How reliable are OEM radiators with plastic end tanks? Has yours failed?
Radiators with plastic end tanks have a reputation for cracking and leaking. Often this happens around 100,000 miles or less. Not a lot of twins have this many miles on them, so maybe that's why I haven't heard of this problem yet with twins. Has anyone experienced leaking plastic end tanks? If so, how is your car used and how many miles are on it?
I'm wondering if it makes sense to replace my OEM rad before it fails and use it as an excuse to buy the Jackson Racing unit that doubles as an oil cooler.
Thanks!
Old 08-03-2018, 01:10 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Thanks!
The real question is why do you need reliability as an excuse? Go for it!
Old 08-03-2018, 01:32 PM   #3
Silvermk2
Drives: Toyota Supra 2JZGTE VVTi
I've had multiple cars with 2-300k miles on the original plastic radiators. I would trust oem over aftermarket imo
Silvermk2 is offline   Reply With Quote
Old 08-03-2018, 02:14 PM   #4
CoolHandMoss
Drives: 2013 FRS
Age as well as mileage plays a role in how long the plastic end tanks last. I'm curious to see how they hold up too though. I intend to have this car quite a while.
CoolHandMoss is offline   Reply With Quote
Old 08-03-2018, 03:19 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
no different than OEM hoses vs "high performance" hoses... they are only as reliable as how well you maintain the car.
the vast majority of coolant system failure comes from stuck thermostat or radiator caps, which overpressurize the system and contribute to premature cracking of hoses or plastic.
Old 08-03-2018, 03:27 PM   #6
100,000+ miles and have never lost a drop of coolant (beyond the expected).
and...
What Spuds said.
Old 08-03-2018, 03:29 PM   #7
Thread crossover:
http://www.ft86club.com/forums/showp...ostcount=46822
Old 08-07-2018, 02:42 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
147k miles here and radiator is fine. I do have coolant evaporation when driven hard but it's done that since I first got it essentially
Old 08-07-2018, 04:56 PM   #9
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Got a leak on my 04 WRX at about 120k. Put another radiator on with plastic ends. Cooling is likely not an issue for the BRZ unless you go FI or tracking.
Ernest72 is offline   Reply With Quote
Old 08-07-2018, 06:12 PM   #10
finch1750
finch1750's Avatar
Yeah, the GD radiators go out between 100-120k miles like clockwork it seemed. My old STi broke at 107k lol
But even tracking the oem rad is very efficient (for NA and even some FI set-ups)
Old 08-08-2018, 01:16 PM   #11
MrDinkleman
Drives: 2016 Oceanic, "base" model
I think it is more than just mileage and age. Environment, # of heating cycles, how long it stays hot each cycle, etc., could be factors. I've only had my FRS for 3yrs and 78k miles so my radiator looks fine.
I also have a 99 Miata on which I had to replace the radiator due to cracked end tank.
Assuming all plastic end tanks are made of the same stuff, you don't HAVE to randomly, preemptively buy a new radiator. The tank on my Miata started to turn green before it cracked. This is a known issue/symptom with Miata OEM radiators. And, it's not like it just exploded, spewing coolant everywhere. I just noticed dried coolant around the filler neck (where it cracked) one day and upon closer inspection, saw the crack.
MrDinkleman is offline   Reply With Quote
Old 08-08-2018, 11:44 PM   #12
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Mine started leaking on my 2003 Lancer at 180k miles. I knew it was dripping because it was dripping. I replaced it for a new unit for like $43 bucks, and it took 30 minutes to install.
Old 08-08-2018, 11:55 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
That must have been tough spending twice the blue book value of the car.
Sorry, can't help myself tonight.
Old 08-09-2018, 12:16 AM   #14
Irace86.2.0
Actually it was three times the value, but at the time a running car is a running car.
Surge tanks and overall fuel capacity flowbiscuit BRZ First-Gen (2012+) — General Topics 40 01-07-2018 12:16 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 06:27 PM
Radiators...which one? Hawk77FT Engine, Exhaust, Transmission 48 07-18-2014 12:06 AM
[WoT] World of Tanks Calidrifter Off-Topic Lounge [WARNING: NO POLITICS] 26 08-07-2013 04:35 AM
How much are you guys paying to fill your tanks? Giccin Off-Topic Lounge [WARNING: NO POLITICS] 64 04-13-2011 01:36 AM
