Drives: 2023 BRZ
How reliable are OEM radiators with plastic end tanks? Has yours failed?
Radiators with plastic end tanks have a reputation for cracking and leaking. Often this happens around 100,000 miles or less. Not a lot of twins have this many miles on them, so maybe that's why I haven't heard of this problem yet with twins. Has anyone experienced leaking plastic end tanks? If so, how is your car used and how many miles are on it?
I'm wondering if it makes sense to replace my OEM rad before it fails and use it as an excuse to buy the Jackson Racing unit that doubles as an oil cooler. Thanks! |
#2 | |
The Dictater
Drives: '13 Red Scion FRS
#3 |
Drives: Toyota Supra 2JZGTE VVTi
I've had multiple cars with 2-300k miles on the original plastic radiators. I would trust oem over aftermarket imo
| The Following User Says Thank You to Silvermk2 For This Useful Post: | Teseo (08-07-2018) |
#4 |
Drives: 2013 FRS
Age as well as mileage plays a role in how long the plastic end tanks last. I'm curious to see how they hold up too though. I intend to have this car quite a while.
#5 |
Drives: 2005 Toyota Camry
no different than OEM hoses vs "high performance" hoses... they are only as reliable as how well you maintain the car.
the vast majority of coolant system failure comes from stuck thermostat or radiator caps, which overpressurize the system and contribute to premature cracking of hoses or plastic. |
#6 |
100,000+ miles and have never lost a drop of coolant (beyond the expected).
and... What Spuds said.
#7 | ||
http://www.ft86club.com/forums/showp...ostcount=46822
#8 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
147k miles here and radiator is fine. I do have coolant evaporation when driven hard but it's done that since I first got it essentially
#9 |
Got a leak on my 04 WRX at about 120k. Put another radiator on with plastic ends. Cooling is likely not an issue for the BRZ unless you go FI or tracking.
#10 | |
But even tracking the oem rad is very efficient (for NA and even some FI set-ups) |
#11 |
Drives: 2016 Oceanic, "base" model
I think it is more than just mileage and age. Environment, # of heating cycles, how long it stays hot each cycle, etc., could be factors. I've only had my FRS for 3yrs and 78k miles so my radiator looks fine.
I also have a 99 Miata on which I had to replace the radiator due to cracked end tank. Assuming all plastic end tanks are made of the same stuff, you don't HAVE to randomly, preemptively buy a new radiator. The tank on my Miata started to turn green before it cracked. This is a known issue/symptom with Miata OEM radiators. And, it's not like it just exploded, spewing coolant everywhere. I just noticed dried coolant around the filler neck (where it cracked) one day and upon closer inspection, saw the crack. |
#12 |
Drives: Q5 + BRZ + M796
Mine started leaking on my 2003 Lancer at 180k miles. I knew it was dripping because it was dripping. I replaced it for a new unit for like $43 bucks, and it took 30 minutes to install.
#13 | |
Famous Potatoes
Drives: '15 ultramarine
Sorry, can't help myself tonight. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | Erick KY (08-11-2018) |
#14 |
Actually it was three times the value, but at the time a running car is a running car.
| Surge tanks and overall fuel capacity | flowbiscuit | BRZ First-Gen (2012+) — General Topics | 40 | 01-07-2018 12:16 PM |
| Nameless overpipe/downpipe welds failed and perrin endlink failed | stockysnail | Northwest | 4 | 01-14-2016 06:27 PM |
| Radiators...which one? | Hawk77FT | Engine, Exhaust, Transmission | 48 | 07-18-2014 12:06 AM |
| [WoT] World of Tanks | Calidrifter | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 08-07-2013 04:35 AM |
| How much are you guys paying to fill your tanks? | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 64 | 04-13-2011 01:36 AM |
