Old 08-01-2018, 09:37 PM   #1
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Street tires for some track use
Howdy,
I'm rocking 225/40R18 Michelin Pilot Sport 4S right now, and while I'm enjoying these tires I feel like I'm leaving some tire performance on the table and I live in an environment where I can run more aggressive tires without much worry driving on the street with them due to weather.
I'm considering the following and I'm curious what the right choice is:
  1. Bridgestone Potenza RE71-R - It's the AutoX classic because of it's 200 treadwear rating and generally are loved
  2. Yokohama Advan Neova AD08R - Used to be 180 treadwear rating, now listed as 200
  3. Toyo Proxes R888R - 100 treadwear rating, basically a street legal racing slick
My driving is about 20% DD, 40% twisties/canyon, and 40% track.
Tristor is offline   Reply With Quote
Old 08-01-2018, 10:20 PM   #2
wparsons
wparsons's Avatar
R888R will be slower and heat cycle out faster than RE71R's, I wouldn't suggest them, especially if you drive in heavy rain at all. They also take more work to get up to temperature and need heat for grip.
RE71R is fast, but will overheat quickly on track (maybe 2 hot laps).
AD08R's aren't as fast as either, but will take 20 minute track sessions easily, and wear like iron. I'm on my third summer with my AD08R's, RS3's lasted me a single summer.
I'd suggest either the AD08R's or RS4's. RS4's are significantly cheaper up here, so that would be my choice.
flickr
Old 08-02-2018, 09:54 AM   #3
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I probably wouldn't run any of those as a dd/canyon and occasional track tire. I've done it with RE-71Rs, and they just wear too fast and are pretty loud.
I also tracked and DD'd ZII Star Specs, which were a much better compromise.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 08-02-2018, 10:31 AM   #4
D-rek07
Any votes for Pilot Super Sports? I daily it. I'm also at two track events and tires still have plenty of tread.
D-rek07 is offline   Reply With Quote
Old 08-02-2018, 11:21 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Federal 595 RS-RR are my go to economy track tire right now.
They last 4 to 6 heat cycles, have decent wear rate, and have decent grip. Price point is good too at approx $400 for a set
Only downsides are road noise and overheat characteristic. They are known to get a little greasy/slick when over heated
EndlessAzure is offline   Reply With Quote
Old 08-02-2018, 01:03 PM   #6
Azzudien
Drives: 2017 Series Yellow BRZ
I have run the R888R's on the street because I am to lazy sometimes to switch them out on track days. I absolutely love the tire on the track.
However, even though they are legal for street use, they are very loud and the noise will make you crawl out of your seat after 15 minutes on the highway.
I run the OEM Michelans on the street, and just put on the R888R's when I arrive at the track now because the noise cured my laziness.
Azzudien is offline   Reply With Quote
Old 08-02-2018, 02:08 PM   #7
Tristor
Tristor's Avatar
PSS don't exist anymore, they got replaced by the PS4S, which is what I'm running right now. They do work pretty decently on the track at my driving level, but I do feel like there's definitely grip left on the table in corners even at stock power levels. On the street they're quite a bit louder than the stock tires, but are otherwise well behaved.
Thanks for all the information guys, it sounds like I may be trying the Yokos next.
Old 08-02-2018, 04:33 PM   #8
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Hankook RS-4 is the real answer. They wear like iron, have excellent grip and ride reasonably well on the street. I've had a set on my 250WHP Miata and loved them.
Lincoln Logs is offline   Reply With Quote
Old 08-02-2018, 04:49 PM   #9
wparsons
wparsons's Avatar
If you're not maxing out the performance, you're likely better off spending money on track time than a grippier tire. Keep what you have until they're totally worn out. The grippier the tire the more they'll cover mistakes.
Any of the extreme performance summer tires are going to be loud, the larger the tread blocks the worse they'll be. AD08R's are definitely louder than the RS3's I had before, and the Dunlop ZII's before the RS3's were louder too.
flickr
Old 08-02-2018, 04:53 PM   #10
Icecreamtruk
Drives: Track preped NA FRS
@wparsons exactly my experience with the R888R. After some heat cycles their magic grip (when brand new) seems gone. They are slower than NT01 (by a fair margin, over a second per minute). What a dissapointement of a tire, honestly. RS4 were better, grip, longevity, easier to heat up. Only the first day at the track did the R888R lived up to the hype.
Old 08-02-2018, 06:16 PM   #11
Tristor
Tristor's Avatar
I agree completely, I need more track time. I'm continuing to pursue on-track instruction. Given how I'm improving though, I think I may only have one or two more track days left in my current tires.
Old 08-02-2018, 07:47 PM   #12
mixxxx
mixxxx's Avatar
Consider the GT Radial SX2. Essentially the spec tire for 86Cup. Lasts a long time, some members can eke out 8 track days on them. Great feedback and very consistent.
Not the grippiest 260TW tire out there but fantastic learning tire.
mixxxx is offline   Reply With Quote
Old 08-03-2018, 01:41 AM   #13
RJasonKlein
RJasonKlein's Avatar
@Tristor, what kind of track driving do you do, autocross or DE? Overall, how do you rate your level of experience?
RJasonKlein is offline   Reply With Quote
Old 08-03-2018, 01:58 AM   #14
ztrevs
ztrevs's Avatar
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
Hankook RS4 is 100% your answer. I just picked up a set for daily/occasional track use and boy are they fantastic. Once you get some heat into them they will stick like nobody's business.
I came from MPSS before switching to RS4s and the road noise was not that much louder. And also note, the RS4 is cheaper than any of those other options you listed.
ztrevs is offline   Reply With Quote
Looking for street/track tires for next year. Lynxis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 08-26-2016 09:42 PM
18" tires for street/track use? .. OR stick w/17" random hero Tracking / Autocross / HPDE / Drifting 35 06-20-2015 09:30 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Evasive Street BRZ Breaks 1:59 Stock Motor and Street Tires Buttonwillow CW13 Video Evasive Motorsports Tracking / Autocross / HPDE / Drifting 31 07-02-2014 01:43 PM
When to replace street tires used for the track? ayau Tracking / Autocross / HPDE / Drifting 4 07-23-2013 11:45 AM
