Old 07-27-2018, 09:17 PM   #1
leunggary
Drives: Scion FRS 2013
Passenger door not getting power?
Problem here okay so
My driver side door window controls have been restarted and driver side window and locks do work but the passenger side is not illuminated and is not flashing.
The driver side controls can lock the passenger door.
The switches that controls the windows on the passenger side windows on both sides do not work. The locks on the passenger side door do not work.
The driver side door controls are not flashing. Switched to a brand new driver side switch control and does not work still.
The passenger side doors do not automatically go up or down when you are opening the door.
Little backstory is that I switched out the driver side door for another door due to a dent that caused fitment issues. Previously, the passenger door worked fully. The original door is a frs the replacement door is a brz.But, all of the electronics are removed from the old frs door and put into the BRZ door.
Help anyone ? Is this an electronic issue where the passenger side door isnt getting power?
Is this a connection issue caused by my autobody shop?
They don't know the issue...
any recommendations are welcome! Thanks
leunggary is offline   Reply With Quote
Old 07-27-2018, 09:37 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Check the fuse box?
Old 07-27-2018, 10:20 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
If you could tell us what you tried already it would've helped.....
Use a multi-meter and check the fuses for the power door controls and such for continuity and for power at the point of the fuse box. If those are fine then it's probably the wiring harness for the door or a relay. If the body shop " dont know the issue" then they aren't really qualified nor are taking the time to diagnose it, therefore you should take it to a dealer.
2017 Toyota 86 Keyless entry unlock passenger door with driver door lowlevel Scion FR-S / Toyota 86 GT86 General Forum 11 09-27-2017 12:30 PM
passenger door and fender Amuse_S2000 Want-To-Buy Requests 1 04-12-2016 01:55 PM
Part passenger door misterfly Issues | Warranty | Recalls / TSB 17 01-06-2016 01:43 AM
passenger door gusbarragan Issues | Warranty | Recalls / TSB 0 04-12-2014 03:04 PM
WTB - Passenger fender and door ty_tap86 Want-To-Buy Requests 3 04-04-2014 09:24 PM
