Old 07-22-2018, 07:26 PM   #1
a_b.95
Question Time
a_b.95's Avatar
Drives: Carbon Covered Boosted 15’ BRZ
Pedal Box’s (classes under brakes?)
Hey guys! Curious as to whether or not there are many of you running aftermarket pedal boxes in your cars and if they’re worth it?
It’s something that I’m looking into doing down the line, but figured it may be worth doing sooner rather than later as I’m having my tubular front end doing soon so could delete some bits that don’t need to be there at the same time!
Thanks!
Owner Of BLACKMARKET
http://www.instagram.com/BLACKMARKET.team
2015’ carbon Covered Turbo BRZ
a_b.95 is offline   Reply With Quote
Old 07-22-2018, 08:39 PM   #2
wparsons
wparsons's Avatar
Worth it in what sense? What's the end goal with the car?
flickr
Old 07-25-2018, 07:49 AM   #3
a_b.95
Question Time
a_b.95's Avatar
Building an OTT Track/Street car... engine build and gearbox conversion early next year.. wondering if the feel / usability / driving experience is improved significantly or not..
Old 07-25-2018, 11:01 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
a_b.95: remember that some parts enhance some parts of experience at expense of compromises in other (eg. worse NVH). Or some enhance so little, so not making investments in those worth it. If nothing else, because same money spent elsewhere would have produced better results. And aftermarket pedal assembly .. imho not worth it.
Old 07-25-2018, 11:37 AM   #5
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Whether it is worth it or not is going to come down to personal preference. I also planned on going to a pedal box. But you lose ABS and then have to figure out the mounting so that it works comfortably with the current DBW pedal and doesn't interfere with anything else under the dash.
The gain is a cleaner looking engine bay and a more precise brake bias. Both of which are minimal gains in a street AND track car. There are enough well thought out brake systems that work with factory set-up.
DustinS is offline   Reply With Quote
The Following 2 Users Say Thank You to DustinS For This Useful Post:
churchx (07-25-2018), wparsons (07-25-2018)
Old 07-25-2018, 01:43 PM   #6
wparsons
wparsons's Avatar
I would say no. You'll get good gains if you need the independent front/rear masters for bias adjustment because you've gone with very different calipers than will work with the factory bias and EBFD.
flickr
Old 07-28-2018, 01:18 PM   #7
a_b.95
Question Time
a_b.95's Avatar
Cheers for the above guys!
Didn’t consider the ABS loss:/ think it’ll stay as it is for now!
Lots to consider, definitely something I want to do as the car gets more na dmore extreme though!
Old 07-29-2018, 08:56 AM   #8
wparsons
wparsons's Avatar
Unless you're doing it for show points, I doubt you'll ever actually need it or benefit from it. Keep in mind ABS also runs the stability control, so you'd be giving up both.
flickr
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Any DIY body shops or classes in PDX? PetrolioBenzina Northwest 4 11-17-2017 10:50 PM
SCCA and NASA classes for 86 platform (wheel to wheel) ddeflyer Tracking / Autocross / HPDE / Drifting 4 10-29-2014 10:08 PM
SCCA Proposes to Ban E-85 in Street Touring Classes Tirewarmer Tracking / Autocross / HPDE / Drifting 31 01-04-2013 12:53 AM
