Old 07-16-2018, 05:46 PM   #1
Ornelas66
Drives: 2015 Scion FRS
P0304 Code resulting in the destruction of Engine on 2015 FRS
My 2015 FRS with 36000 miles started to have trouble idling. The check engine light went on and I took it to auto parts store to have it analyzed. I took the car to Subaru dealership and the said the problem was in the number 3 cylinder. The changed the coil with the number 4 cylinder but the problem continued. They also switched the spark plugs, but the problem continued. They charged my $138 for the diagnostic and said that it had a cracked cylinder. Since they are a Subaru dealership, they could not repair it under warranty, but recommended I take it to the Boerne Toyota for repairs. They even recommended the Sales Adviser.
Today the Sales Adviser called and said that the item isn't covered under warranty because my FRS was modified. The only modifications have been:
-quick drain oil plug
-aftermarket air filter
-oil cooler
-catch can
-front strut brace
-rear strut brace
-brake pedal brace.
My repairs aren't going to be covered. Do you guys have any recommendations. Repairs are in the three thousand dollar range
Ornelas66 is offline   Reply With Quote
Old 07-16-2018, 05:49 PM   #2
steelheart100
steelheart100's Avatar
Drives: 2019 Toyota 86 TRD edition
I would call Toyota directly and have them open a case.
steelheart100 is offline   Reply With Quote
Old 07-16-2018, 06:05 PM   #3
displacedTexan
displacedTexan's Avatar
Drives: '13 FR-S 10 Series
-oil cooler
-catch can
-front strut brace
-rear strut brace
-brake pedal brace.
Did the dealership submit the claim to Toyota, or does the dealership not want to submit the warranty claim? If the dealership hasn't submitted the claim, you could contact another dealership to see what they say about the car being modified. I was told that once the claim is submitted to Toyota, taking the car to another dealership is pointless. Might be something to consider.
I started working up the chain on my warranty claim by talking to the service manager, then the general manager, then Toyota Customer Relations. I had to contact customer relations twice and push hard for an FTS to go look at my car before Toyota even sent someone from corporate to look at the engine.
displacedTexan is offline   Reply With Quote
Old 07-16-2018, 06:11 PM   #4
Ornelas66
NEWS Update:
Dealership said that it was not a cracked ring in the number three cylinder, but a broken direct injector in the number four cylinder. The direct injector isn't covered because it is over 36,000 miles. The service tech says that when he checks the car under the multiport injector, it is fine, but when he switches to direct injections, it gets the shakes.
The cost to repair the direct injector is $1,450
Old 07-17-2018, 01:04 PM   #5
Lonewolf
Lonewolf's Avatar
Drives: Moped
NEWS Update:
Why isn't the direct injector covered (it is a vital part of the powertrain, and should fall under 5 yrs./60K warranty unless specifically excluded)?
Old 07-17-2018, 01:21 PM   #6
ermax
ermax's Avatar
NEWS Update:
Jesus, I am in the wrong business. A new direct injector is $172 MSRP and that comes with all new o-rings. You have to remove the manifold so you would need a new gasket there too. So they are getting a ton of money in labor. The job really isn't that bad. Not enough labor to justify $1300.
I suspect the injector itself is fine and it's just a seal that is bad. The seals are $3 but need a special tool ($120) to replace them.
Have you been hearing any popping from the engine bay? Typically bad DI seals produce what people refer to as "firecracker sounds". If you don't have that symptom then maybe it isn't just a bad seal.
Regardless it sounds like they are looking to profit off something that should be covered under powertrain.
Old 08-09-2018, 06:40 PM   #7
Lonewolf
Lonewolf's Avatar
Drives: Moped
NEWS Update:
So, what happened with this situation?
Old 08-24-2018, 10:00 PM   #8
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Don' ghost us!
CB750F is offline   Reply With Quote
P0300 and P0304 CEL -- uh oh! empower-auto Issues | Warranty | Recalls / TSB 26 04-16-2018 03:19 PM
HELP code P0102 engine goes on and off aldo29199 Engine, Exhaust, Transmission 5 07-26-2016 07:57 AM
P219A ENGINE CODE Albaro08 Issues | Warranty | Recalls / TSB 6 12-29-2015 05:15 PM
P0328 Engine Code Lil Abner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-23-2014 12:10 PM
Destruction Perihelion Scion FR-S / Toyota 86 GT86 General Forum 9 07-12-2013 03:42 PM
