Old 07-05-2018, 11:56 PM   #1
MotoGrapher
Drives: 2014 White BRZ Limited
Screwed up. Connect jumper cable run way
Simple task, dark night, shit happened.
I was trying to jump my BRZ from a Camry tonight but connected the jumper cable the wrong way. I left it wrong for about 5 seconds and then corrected it.
Now the car can start but there are all different kinds of warning lights on the dash. I have no power steering, no auto navi screen, no auto headlights (but the manual low/high beam still works fine).
I searched around and people are talking about the MAIN FUSE, I checked all small fuses in the engine bay using multimeter and they are all good. But did not check the main fuse.
Based on the symptom, do you guys have any ideas?
Thank you in advance!
MotoGrapher is offline   Reply With Quote
Old 07-06-2018, 01:33 AM   #2
Abdulb
Drives: 2013 FR-S 6 speed
It's the main fuse. Sometimes the starter goes too but if your car is starting up then just change the main fuse and you should be good to go.
Abdulb is offline   Reply With Quote
Old 07-06-2018, 07:32 AM   #3
MotoGrapher
Hi, do you mean the fuse on the battery positive terminal?
Old 07-06-2018, 04:33 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Look for blown fuses.
Replace.
Try to start car.
JTFC
Old 07-06-2018, 09:08 PM   #5
humfrz
I do believe that is the one he is referring to.
humfrz
Screwed up. Connect jumper cable run way MotoGrapher BRZ First-Gen (2012+) — General Topics 3 01-28-2021 02:42 PM
Blitz VSC Jumper for 86/FR-S/BRZ mav1178 Tracking / Autocross / HPDE / Drifting 3 12-14-2016 02:17 PM
Reverse cable dropped. Am I screwed? BFIFE22 BRZ First-Gen (2012+) — General Topics 2 02-25-2016 04:31 PM
well im screwed marine321 Scion FR-S / Toyota 86 GT86 General Forum 59 12-17-2012 10:00 PM
Help!! No sound when connect my ipod/iphone with cable percyng Electronics | Audio | NAV | Infotainment 16 06-21-2012 04:20 AM
