Old 07-05-2018, 11:55 PM   #1
MotoGrapher
Drives: 2014 White BRZ Limited
Screwed up. Connect jumper cable run way
Simple task, dark night, shit happened.
I was trying to jump my BRZ from a Camry tonight but connected the jumper cable the wrong way. I left it wrong for about 5 seconds and then corrected it.
Now the car can start but there are all different kinds of warning lights on the dash. I have no power steering, no auto navi screen, no auto headlights (but the manual low/high beam still works fine).
I searched around and people are talking about the MAIN FUSE, I checked all small fuses in the engine bay using multimeter and they are all good. But did not check the main fuse.
Based on the symptom, do you guys have any ideas?
Thank you in advance!
MotoGrapher is offline   Reply With Quote
Old 07-06-2018, 12:44 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Try disconnecting both terminals from your battery, then reconnect them. Remove negative first, then positive, and attach in reverse order. Be careful with the positive side not to touch another part of the car while touching the terminal.
There's also a small fuse in the positive lead. That might be the "main" fuse?
Old 07-06-2018, 12:53 AM   #3
MotoGrapher
Actually just took another look, the 140 fuse on the positive terminal was blown...
I am going to order the part hopefully that will fix the issue.
Old 01-28-2021, 02:42 PM   #4
pr0phet129
I know it’s an old thread
But did replacing the main fuse fix it?
pr0phet129 is offline   Reply With Quote
Blitz VSC Jumper for 86/FR-S/BRZ mav1178 Tracking / Autocross / HPDE / Drifting 3 12-14-2016 02:17 PM
Reverse cable dropped. Am I screwed? BFIFE22 BRZ First-Gen (2012+) — General Topics 2 02-25-2016 04:31 PM
well im screwed marine321 Scion FR-S / Toyota 86 GT86 General Forum 59 12-17-2012 10:00 PM
Screwed. Helix Southeast 39 07-22-2012 07:22 PM
Help!! No sound when connect my ipod/iphone with cable percyng Electronics | Audio | NAV | Infotainment 16 06-21-2012 04:20 AM
