Old 07-02-2018, 02:47 PM   #1
neroman98
Drives: 2014 Scion FRS Track Build
Which oil cooler for GPP Turbo?
Hey guys,
I’m planning on purchasing the new GReddy GPP Turbo kit with the 2871R turbo, and I was wondering what oil cooler I should get? The car is a track build and my intentions are to hit 350 wheel on E85. I’m trying to decide which oil cooler will provide proper cooling on a hot California day and will not interfere with the turbo. I’m leaning towards the Jackson Racing Dual Radiator/Oil Cooler since it will not interfere with the turbo and has almost the same oil cooling capabilities as their standalone oil cooler. Thoughts?
Thank you!
neroman98 is offline   Reply With Quote
Old 07-02-2018, 05:22 PM   #2
You can hit 350whp on E85 with their smallest turbo kit, which has a plug-and-play oil cooler solution.
Thoughts?
This is my car with the T518Z kit.
If you're set on the V3 kit, the Jackson Racing dual radiator oil cooler would be the easiest drop-in solution.
advice, cooling, greddy, oil cooler, turbo
Oil cooler setup on a turbo car. 86Craze Forced Induction 5 10-03-2017 09:25 AM
WTB Oil cooler kit, clutch kit, map turbo kit Sereious Want-To-Buy Requests 0 08-24-2015 10:41 PM
Poll: Oil cooler kits with oil fed turbo kit sw20kosh Forced Induction 0 07-27-2014 11:19 AM
Which turbo kits work with the Perrin oil cooler? DrewsBRZ Forced Induction 10 07-18-2014 09:23 AM
P&L Turbo Kit Oil Cooler Compatibility enjoyminutemaid Forced Induction 4 05-15-2014 03:41 PM
