Old 07-02-2018, 12:50 AM   #1
Alpha86
Drives: 2013 Firestorm Red FRS
Which Coil Is Right For Me?
Hey guys, after doing a whole lot of research, I'm between a couple of options for coils:
-Tein Flex Z
-Bilstein B14 PSS (These are very appealing but dont seem to come with top hats or swaybar links, which would be great)
-K-Sport Kontrol Pro
-Skunk2 Pro-C
My budget is $1000-$1500, will go slightly higher IF the quality/performance is higher for a minimal price difference. I dont mind a stiff ride, as long as I wont need a chiropractor after every drive, and I will not track the car anytime soon. I mainly want the maximum street/back road performance possible and getting rid of wheel gap.
Alpha86 is offline   Reply With Quote
Old 07-02-2018, 01:52 AM   #2
humfrz
-Tein Flex Z
-Skunk2 Pro-C
Hello Alpha86, and welcome to our forum...
Considering your objectives, have you considered some simple lowering springs? Like:
http://www.ft86speedfactory.com/race...l#.Wzm8ePZFwcQ
humfrz
Old 07-02-2018, 02:17 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What about the ST coil over? These are pretty much KW V1's. They have fairly soft spring rates. I am on the Flex Z. They are pretty rough on the street, and with the camber plates they come with, they transfer a lot of NVH.
http://www.ft86speedfactory.com/st-s...l#.WznDA6dKjrc
Old 07-02-2018, 02:40 AM   #4
RIĐO
RIĐO's Avatar
Drives: orange car
Bilstein for sure. You don't need links and top hats for your application.
RIĐO is offline   Reply With Quote
The Following User Says Thank You to RIĐO For This Useful Post:
strat61caster (07-02-2018)
Old 07-02-2018, 03:21 AM   #5
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
what @humfrz said... if you are only seeking to lower the car and not really for performance, just go with lowering spring... its cheaper and it achieves what you need. especially if you are not doing any kind of motorsport.
slyphen is offline   Reply With Quote
Old 07-02-2018, 03:14 PM   #6
Alpha86
humfrz
Thanks for the welcome! I have considered lowering springs briefly, and they arent out of the question entirely. The reason I wanted coils specifically is so I can adjust ride height based on my wheel and tire choice, eventually I'll be getting 18x8" wheels for the summer and keeping the stock 17" for the colder seasons.
The Following User Says Thank You to Alpha86 For This Useful Post:
humfrz (07-02-2018)
Old 07-02-2018, 03:55 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Alpha86: if not using BBK, why not use 16" for winter?
Old 07-02-2018, 04:32 PM   #8
CSG David
CSG David's Avatar
-Tein Flex Z
-Skunk2 Pro-C
CSG Spec TEIN Flex A are well within your budget.
https://www.counterspacegarage.com/t...spec-toyota86/
The Following User Says Thank You to CSG David For This Useful Post:
TurtReynolds (07-03-2018)
Old 07-02-2018, 05:04 PM   #9
carlovestela
Drives: 2015 Firestorm FRS
Would you recommend tein flex z?
carlovestela is offline   Reply With Quote
Old 07-02-2018, 05:25 PM   #10
-Tein Flex Z
-Skunk2 Pro-C
How about CSG Spec Flex A? Within your budget, accomplishes your goals.
Stiff/harsh ride means that instead of the suspension absorbing the road and maximizing grip, it's passing it to the chassis with a higher potential to lose traction.
http://www.ft86club.com/forums/showthread.php?t=126107
Old 07-02-2018, 05:26 PM   #11
Have you tried adjusting your settings?
Old 07-02-2018, 06:01 PM   #12
strat61caster
strat61caster's Avatar
B14's ride pretty similar to stock when lowered <1" as above you don't need anything else (although camber bolts are a worthwhile addition imho). I never went lower but they may get a little harsh as you begin relying on the bump stop.
Other coilovers probably ride better when lowered, Bilstein seems to target that 'oem+' feeling which means that they don't go too far outside the box.
ineedyourdiddly
Old 07-02-2018, 11:26 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I have changed ride height, spring preload, and backed off the adjusters. It is better then it was but still kind of rough. I have never fully backed off the adjuster as I am not that bothered by it.
Old 07-03-2018, 12:24 AM   #14
Set ride to recommended or higher. Zero preload. try 8 clicks front/rear. Align.
It should be smoother than stock, except over LARGE bumps.
NoHaveMSG (07-03-2018)
Im buying coil overs within the next 2 days i need help deciding what coil overs Anthony7515 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-30-2014 08:47 AM
Im buying coil overs within the next 2 days i need help deciding what coil overs to Anthony7515 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-27-2014 01:00 PM
Stance Coil overs or BC coil overs ? tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 11-26-2013 04:13 AM
Another bad coil, and more! Mr 286 Issues | Warranty | Recalls / TSB 6 06-18-2013 10:26 PM
