Old 06-26-2018, 05:45 PM   #1
2nd86
Drives: Hot Lava FR-S
2013 FR-S OEM Pioneer Head Unit issue
Hello,
I've been driving for 6 years and 60,000 miles, and all the sudden my stereo is stuck in Bluetooth mode. If i press AM/FM, disc, etc. (the other three sides of the plus-shaped button) nothing happens. I've tried disconnecting and reconnecting my phone, turning the unit on and off, and pushing all the various buttons.
Is there some kind of hard reset, like on so many computerized things, (realizing how old I sound right now) or does it seem like that button has physically broken?
Thanks for any advice or tricks I can try.
2nd86 is offline   Reply With Quote
Old 06-26-2018, 05:55 PM   #2
Chimera
Drives: FRS
Battery pull for 30s?
Old 06-26-2018, 06:12 PM   #3
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
Try disconnecting the battery for 15 seconds or so and then reconnecting for a hard reset. Most infotainment systems actually never turn off completely. You might also go through the settings and find the reset menu to factory setting item (if it has one). This will erase your data in case the data is corrupted. I'd probably erase the data first and then do the hard reset. If it is a systems problem, that will probably fix it. However, if it is a hardware issue, that won't. It could be in the switch or it could be some sort of circuit board glitch. If your unit is still under warranty, then there is a fix. If not, you may be looking at replacing the unit which not a cheap thing to do. Good luck.
rvoll is offline   Reply With Quote
2013 OEM FR-S Pioneer Head Unit eurominican Audio/Visual, Electronics, Infotainment, NAV 3 05-03-2016 09:40 PM
Feeler: Scion Pioneer Head Unit (2013 upgrade) drewbot Canada Classifieds 4 02-12-2015 09:33 AM
**SOLD***2013-14 Scion FR-S 6.1" Pioneer Navigation Head Unit w/ AHA module extension Lverasky Audio/Visual, Electronics, Infotainment, NAV 7 11-23-2014 12:59 PM
FS: FRS pioneer head unit ironsurfer129 Audio/Visual, Electronics, Infotainment, NAV 6 02-27-2014 09:27 AM
2013 Scion Pioneer Premium Audio Head Unit, $125 [SOLD] normancw Canada Classifieds 7 01-07-2014 09:10 PM
