Drives: '13 Scion fr-s
Need suggestions of how to raise my '13 fr-s up by a little bit
Hi guys, I'm facing the problem where the driveway to my garage is very steep. It is steep to the point that my front lip will just barely scrape the ground at the bottom of the ramp. This is a huge pain and the ass and my only solution right now is to reverse down the ramp, as the rear seems to have enough clearance to not scrape the ground. This works well enough, but unless I'm going down at exactly the right spot, I can still scrape the ground. There is no ability to angle the car at all, as it is a very tight ramp squeezed between two buildings with not much wiggle room to go down at an angle.
At the moment, my car is a pretty much completely stock daily driver. No modifications to the suspension or anything. I am not a very technical guy and the only thing I really do besides wash my car is swap the tires out myself for the winter. Here are some solutions I have thought of:
Does anyone have any better ideas? Or of the three, which would be the best idea? I like the idea of spacers, but can't seem to find any good installation instructions. I'm really not a mechanic or wrencher and am not super confident in my abilities to just start replacing parts. How difficult of a job would this be for an average joe? |
#2 | |
Site Moderator
Drives: ichi 86 Project
1) This is the very first time I've ever heard of different tire sizes changing the speedometer. Interesting and I will read into that. What steps do you need to take to change the speedometer?
2) If I go with 1" suspension spacers at the front and back, like what's offered by the one I have been looking at by Subtle Solutions (here), would I need this camber bolt? How do I know if I'd need a camber bolt? 3) Do you have any coilover suggestions that could raise my car up by about an inch? |
#4 | |
Drives: 2018 BRZ Limited, 2017 Sportage
You could always have an asphalt or concrete guy fill in some of the dip at the bottom of your driveway. That may well be cheaper depending on where you live. Otherwise, totally agree with the previous poster. |
| The Following User Says Thank You to rvoll For This Useful Post: | H_K (06-25-2018) |
#5 | |
If only I had that kind of money, haha. Though, probably cheaper than a complete tire swap x2 (summer and winter) and wheel swap
Drives: '14 981CS, '99 NB1
long 2x4 or 2x8 placed at the bottom of the ramp where it meets the street. I did this at one place I lived. Worked fine for years.
| The Following User Says Thank You to johan For This Useful Post: | Mr.ac (06-25-2018) |
#8 | |
Do you think a 215/50R17 tire would give me any problems with the speedometer? That seems much taller and looks like it would give me about 21mm more in diameter (about .8 of an inch). 215/55R17 would give me 43mm (1.69 inches). |
I like the idea, but it is a shared condo driveway that probably wouldn't be interested in letting me put some materials down on the ramp.
#10 |
| The Following 4 Users Say Thank You to johan For This Useful Post: |
#11 | |||
Site Moderator
2. I don't remember stock bolts can adjust as much... so just look for whiteline or other well known brand camber bolts. I, myself have Whiteline. 3. Tein, RSR, HKS, Apex, Ohlins, Cusco and list just goes on and on. It's all depends on how much you're willing to spend. I have RSR, but that's a bit different story. I like Cusco too. Just 2 yen. Quote:
Reading/Actual 20/20.7 30/31.1 40/41.5 50/51.8 60/62.2 70/72.6 80/82.9 90/93.3 Quote:
#12 |
#13 |
Site Moderator
Those number are:
Tire sizes 215/45/17 vs 215/50/17 Speedometer reading: Reading/Actual 20MPH/20.7MPH 30MPH/31.1MPH 40MPH/41.5MPH 50MPH/51.8MPH 60MPH/62.2MPH 70MPH/72.6MPH 80MPH/82.9MPH 90MPH/93.3MPH If you get 215/50/17 tires and you're driving and see the gauge you're going 50MPH, but you're actually going 51.8MPH. |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | H_K (06-25-2018) |
#14 | |
My driveway is quite steep with a crown at the top. So, our Saturn has been scraping it's front bumper for the past ten years, going out of the garage. I just cringe a little, then shake it off. My FR-S (not lowered) high centers on the crown by the sidewalk going out 2 out of 10 times. It's rubbing on the resonator, which, after 4 years seems, to be holding up real well. You most likely won't be living there and driving your FR-S the rest of your life … so, it's a temporary thing... ![]() Besides, just how much time do you spend laying on the ground looking up at the scratches on the underside of the front lip ..?? ![]() Hey, I'm relatively old and have learned over the years, not to worry about stuff like that... humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | HKz (06-26-2018) |
| Does OFT raise rev limiter? | MurderRider | Software Tuning | 45 | 07-29-2016 01:23 AM |
| Raise or stay? | Bongertz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 07-16-2014 04:12 AM |
| Raise or stay? | Bongertz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-03-2014 12:57 AM |
| Raise BRZ | djenriquez07 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 08-14-2012 01:28 PM |
