Old 06-24-2018, 10:48 PM   #1
teabubblez
Drives: BRZ 2018
2017+ BRZ Headlight, DRL Wiring Help
Hi guys, I am trying to install the 2017+ JDM DRL, but from what I am aware the USDM BRZ does not have the proper harness.
My plan is to create a Y-harness (1x8pin[headlight] + 1x4pin[DRL] -> 8pin[headlight]).
I purchased the following connectors off Aliexpress (b/c Toyota wanted $40CAD per wire . . . )
- 8pin - 90980–10896/90980–10897
- 4pin - 90980–11027/ 90980–11028
--They come with the connector, pins and seals.
I have two questions that I am trying to figure out:
1. There are 2 ground pins (or 3, trying to figure out what the last pin is for)
Which do I tap into? (I assume that one is for low beam, one for high beam and one for everything else)
2. Does anyone know what gauge wire is used for the headlights? There is one thick wire and 6 others are the same.
According to the wiring pdf the part (82998–12430) - wire outside diameter is 2.6mm and nominal size is 2.00
The pinout is (driver side)
[Low-Beams | Ground | High-Beams | X ]
[DRL |Turns | unknown | Ground ]
Thanks!
teabubblez is offline   Reply With Quote
Old 07-06-2018, 09:12 PM   #2
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
Thanks!
the easiest way is to tap into ignition in the engine bay fuse box
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 07-09-2018, 04:23 PM   #3
Mazikowski
Drives: 2013 GBS BRZ Limited
Slightly off topic question... where did you find the part numbers for the connectors?
Mazikowski is offline   Reply With Quote
Valenti Headlight Wiring Help electrongeek Cosmetic Modification (Interior/Exterior/Lighting) 34 04-17-2024 08:51 AM
WTB BRZ OEM headlight ballasts and wiring Hot Wheels Want-To-Buy Requests 0 05-15-2016 04:51 PM
headlight wiring problem VakaGT Cosmetic Modification (Interior/Exterior/Lighting) 0 12-30-2014 02:41 AM
headlight wiring question Lydin Cosmetic Modification (Interior/Exterior/Lighting) 0 04-11-2014 10:02 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 09:24 PM
