Old 06-13-2018, 08:12 PM   #1
spicetooth
Drives: 2014 FR-S
Smile Help with exhaust system purchase
Hey All,
I have a stock 2014 FR-S. I've read and watched a ton of content on headers and cat backs. I know I love the sound of the Gruppe-S UEL header and Invidia r400 cat back.
Here is the dilema. We have emissions testing in Ontario Canada. I cannot seem to find an answer anywhere on if I can pass etest with a catless header.
If I can't, I don't mind doing a catted header and mid pipe but want to make sure I still get that awesome low tone boxer rumble. No idea where to start.
Also, I do not like high RPM raspyness or cabin drone as I use the phone a lot in the car.
Any help is greatly appreciated.
spicetooth is offline   Reply With Quote
Old 06-13-2018, 08:23 PM   #2
J1Avs
Drives: 2018 BRZ tS
I’m running the Perrin 2.5 Resonated and will be installing JDL Catted UEL and JDL Catted/Resonated Front/Over Pipe Combo in about a week. Check out some clips on the combo, it has a real nice deep tone and subie rumble without any rasp. I delt with JDL directly over the phone and email and they were great to work with. Only downside is JDL is way more than the Gruppe. I chose going Catted on both to be as safe as possible for emissions.
J1Avs is offline   Reply With Quote
Old 06-13-2018, 09:40 PM   #3
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
you most likley wont pass an etest with a catless header. The etest if i'm not mistaken checks for CELs and running without a cat throws one due to the difference in airflow. Even if you get a tune, which removes it, wont have the airflow that a stock system should have so you might fail there.
But i'm also in California, where if i change my shift knob i fail smog...
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 2 Users Say Thank You to Xxyion For This Useful Post:
Timmy_Jones (06-18-2018), Turbo (06-13-2018)
Old 06-13-2018, 10:40 PM   #4
Turbo
Drives: FR-S Turbo
Turbo is offline   Reply With Quote
Old 06-13-2018, 11:16 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
'Murica!
MS, CSCS, TSAC-F, CPT
Old 06-14-2018, 01:39 AM   #6
NRXRaptor
I'm in California too. The only smog testing required for me is on change of vehicle ownership according to dmv.ca.gov. Git gud
NRXRaptor is offline   Reply With Quote
Old 06-14-2018, 01:24 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Only if you are in enhanced testing areas, mostly urban centers or the central valley.
https://www.bar.ca.gov/pdf/Program_Map.pdf
Old 06-14-2018, 02:48 PM   #8
Xxyion
Lowly Cartuber
Xxyion's Avatar
SF Bay area is smack dab right in the middle of the orange area on the map you provided. Thats where i live unfortunetly
Old 06-14-2018, 03:03 PM   #9
Hudson456
I'm absolutely in love with my Tanabe Concept G single exit. There is ZERO drone cruising around town, the sound at WOT is louder than stock but doesn't exceed 93 db (per Tanabe) and sounds great. I also dropped 20 lbs swapping from stock.
If you like the look of single exit it is a solid choice!
Hudson456 is offline   Reply With Quote
The Following User Says Thank You to Hudson456 For This Useful Post:
SuperTom (06-14-2018)
Old 06-14-2018, 04:29 PM   #10
mav1178
mav1178's Avatar
Which is why I posted the map, because not all of CA is under the same rule you are suggesting.
-alex
Old 06-14-2018, 07:28 PM   #11
Xxyion
Lowly Cartuber
Xxyion's Avatar
-alex
I was just making a joke lol
Old 06-15-2018, 12:59 AM   #12
spicetooth
Drives: 2014 FR-S
Thanks for all of your feedback so far.
I found out we only do ECU etest here now and I'm good for another 3 years anyway.
Seems the r400 with any catless UEL sounds great as long as there is a resonator on the front pipe.
Sent from my ONEPLUS A3000 using Tapatalk
Old 06-15-2018, 01:08 AM   #13
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The gruppe UEL is a good choice, I plan to get that when this header gets too worn out.
The gruppe is made in the same place as the tomei
Old 06-15-2018, 12:58 PM   #14
spicetooth
Drives: 2014 FR-S
If I buy UEL header, overpipe and cat back as shops recommend, does that mean I am sticking with the stock front pipe that has a cat in it?
MagnaFlow Promo - Free $100 Gift Card w/ Purchase + Exhaust Giveaway! RallySport Direct Engine, Exhaust, Bolt-Ons 3 03-08-2018 10:50 AM
FI Exhaust - Valve Exhaust System GT86,BRZ,FRS Chefsache Engine, Exhaust, Bolt-Ons 6 10-06-2016 01:56 AM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Exhaust Purchase Wilson15 CANADA 39 03-10-2014 07:28 PM
Where is the best place to purchase A TRD exhaust speedy racer Engine, Exhaust, Transmission 22 07-31-2013 12:51 PM
