Old 06-12-2018, 10:34 PM   #1
btan219
Drives: DGM 15' BRZ Limited
Question about torque wrench usage.
Looking to buy a torque wrench so I can accurately tighten the bolts I'll be working with. The maintenance I plan on doing are: oil changes, transmission oil, rear differential oil, and tires.
This is going to be my first time buying a torque wrench and I'm not very knowledgeable about tools so I had a couple of questions before I make my purchase to make sure I have everything to do all of my oil and tire changes.
I currently have this tool box which has a 3/8" drive ratchet, and 14mm (for oil change) and a 10mm (for trans/rear diff) drive sockets:
https://www.amazon.com/dp/B009EMKLDG...ing=UTF8&psc=1
I'm looking to buy this torque wrench: https://www.amazon.com/dp/B00C5ZL0RU...v_ov_lig_dp_it
but it is an 1/2" drive wrench and my drive sockets are 3/8" so I should get this adapter so I can use my drive sockets with the torque wrench? https://www.amazon.com/dp/B00OIZ86HW...v_ov_lig_dp_it
And I've read one of the bolts for rear differential/transmissions requires a hex socket and i was looking to buy this: https://www.amazon.com/dp/B002YKLA8U...v_ov_lig_dp_it
I'd use one of the adapters from above on my 3/8" wrench so I can use the 1/2" hex bit drive socket.
Do I have everything correct, or am I missing something?
Also, do they sell individual drive sockets to connect to the 1/2" torque wrench for tire lug nuts? I've tried searching for 12x1.5 drive socket couldn't find anything.
Thanks!
btan219 is offline   Reply With Quote
Old 06-12-2018, 10:52 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
The adapters you seek are shown right at the bottom of the page. I suggest a quick trip to a decent hardware or auto parts store and just browsing around for ideas. At your level, I guarantee it will be worth it.
I don't see a breaker bar on your shopping list. I don't like the style suggested on that page. I've easily bent one. Look for something like this one. Notice the difference in the head.
Also, you're referring correctly to the size and pitch of the fastener. Keep in that habit. However, that M12x1.5 hex head acorn nut uses a 19 mm socket. Get a deep well (long) style. It'll help you keep from scratching your wheels and fenders.
Old 06-12-2018, 11:50 PM   #3
humfrz
Congratulations on wanting to learn how to do basic maintenance on your vehicle.
My advice on tool purchases is that for your average shade tree (garage) weekend mechanic, you don't need the most expensive tool on the shelf. Something between Snap-On and Kmart will do nicely.
I reckon the same goes for a torque wrench, after all, you're not building a rocket ship.
I have a torque wrench around here somewhere, the last time I used it was to tighten the head bolts on a 1948 Chevrolet. Over the years, most people can look at a fastener and get a pretty good idea of how tight "tight-enough" is. The longer you "wrench" the more calibrated your wrist will become.
Parting hint: NEVER trust a jack - always have a back up in place.
humfrz
PS - as far as ol @Ultramaroon 's recommendation for a breaker bar …. keep in mind he is a BIG guy and given that breaker bar, he could most likely turn over a tank if he could find a big enough of bolt on it ..
Spuds (06-13-2018)
Old 06-13-2018, 12:11 AM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Since we are on the subject of breaker bars, DO NOT use your torque wrench as a breaker bar, or to loosen bolts. Use it ONLY to tighten bolts to a torque value within the range of the bar. Anything else will damage it.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
humfrz (06-13-2018), Spuds (06-13-2018)
Old 06-13-2018, 12:32 AM   #5
Ultramaroon
not playing cards
Don't listen to old @humfrz. He learned wrenching from his drinkin' buddy, Bubba. Now, ol' Bubba liked to think his hands were calibrated but every time he tightened down a fastener, he tightened just a little bit too much. That's why his nuts and screws always seemed to strip out after the fifth or sixth time he tightened them.
Use a torque wrench.
humfrz (06-13-2018), JohnJuan (06-18-2018), Tristor (06-15-2018)
Old 06-13-2018, 12:50 AM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I just have a Harbor Freight clicky torque wrench. Works fine for me. My opinion, you only really need to get within +-10% of the specified torque values in most automotive applications. Any brand of wrench will get you there if you treat it right and don't abuse it. Looks like that tekton torque wrench will be fine for what you need. I'm pretty sure I have that exact set of adapters you linked, and they work great.
I find a good sturdy ratchet and a rubber mallet is enough for breaking everything under the car free. I wound up needing an impact driver and associated bits for removing wheels. Saves a TON of time over a breaker bar/tireiron, and you don't need to stop the wheels from turning.
As for tightening drain plugs, I just tighten until it's firm with a regular ratchet. If it doesn't leak, and you can get it off again...
Edit:. Oh! And a magnet on a stick. You don't realize how important it is until you need it. Like I just found out today... Not really necessary for oil changes and such, but you will need it one day.
The Following User Says Thank You to Spuds For This Useful Post:
humfrz (06-13-2018)
Old 06-13-2018, 01:04 AM   #7
humfrz
Yep, @btan219 , to clarify, it's a good idea to use a torque wrench when you start out wrenching. That's the way you calibrate your wrists...
Of course some of us "learned" the calibrations the hard way. If it's in July and you are in a hot hayfield on the back 40 and you break a part on the hay baler and have to fix it before the due sets in on the hay, you learn to do it right the first time. You walk back to the barn, dig through wooden fruit boxes and coffee cans of old rusty bolts or nuts till you find a replacement.
After walking back to the field, you replace the broken bolt/nut and you learn "tight-n-niff" real quick or you have to rinse and repeat …
humfrz
Tristor (06-15-2018), Ultramaroon (06-13-2018)
Old 06-13-2018, 02:04 AM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
100% right on.
Drain plugs you don't really need to torque them down. But you do need a torque wrench for other stuff.
What every dude/chick should have is a nice beefy 1/2" torque wrench that can go more than 130ft/lb. and a 3/8" small torque wrench that reads "inch"/lbs.
Also make sure you know the difference between inch/lbs and ft/lbs call out. Last thing you want to do is use your brand new 1/2" torque wrench on the oil drain plug and set it for 50ft/lbs. that's a sure way to strip out the threads.
The Following User Says Thank You to Mr.ac For This Useful Post:
Spuds (06-13-2018)
Old 06-14-2018, 10:25 PM   #9
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
You may want to look into a fumoto valve too, quicker , less messy
http://www.fumotooildrainvalve.com/?...modelId=524299
CB750F is offline   Reply With Quote
The Following 4 Users Say Thank You to CB750F For This Useful Post:
carsebuco (06-14-2018), JohnJuan (06-18-2018), Spuds (06-14-2018), Tristor (06-15-2018)
Old 06-14-2018, 10:35 PM   #10
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
I have these on, and if you thought oil changes on the triplets couldn't get any easier from stock, you'll laugh maniacally the first time you use this.
carsebuco is offline   Reply With Quote
The Following User Says Thank You to carsebuco For This Useful Post:
Old 06-14-2018, 10:49 PM   #11
Spuds
The Dictater
Spuds's Avatar
Can confirm, I laughed maniacally the first change after I installed it.
Old 06-14-2018, 10:51 PM   #12
Ultramaroon
not playing cards
But that's because you're a maniac, not because of the valve.
Mwah ha ha haaaa!
Old 06-14-2018, 11:04 PM   #13
Spuds
The Dictater
Spuds's Avatar
Mwah ha ha haaaa!
Can confirm, I laugh maniacally at many things. Including, but not limited to: fancy drain plugs, cheese
Tristor (06-15-2018), Ultramaroon (06-14-2018)
Old 06-15-2018, 04:55 PM   #14
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I wouldn't skimp too much on the torque wrench. I have, I guess, four or five. The school I went to used the same curriculum as Humfrz. We used (and sometimes cursed) the "Armstrong" torque wrenches most of us had. In addition to farm equipment, however, I spent a lot of years working on 60s and 70s vintage Japanese and British motorcycles. As a general rule the fasteners were soft and the cases softer. The cost of breaking a bolt in a blind hole or stripping that hole could be pretty high. I have a nice collection of heli-coil sets in 5 to 10mm as a legacy. So, I torque fasteners more often than not.
I suggest eventually acquiring a 1/4" drive 20-140 inch/pound, a 3/8" 5-75 ft/lb, and a 1/2" 20-150 ft/lb. An 18" breaker bar is nice as is are sets of square drive allen and torx sockets and duplicate sets of your most used box/combination wrenches.
I have several air impacts but a decent electric one can will do, and can be a big time/aggravation beater. Just don't use it to tighten anything.
A couple of things I use a lot are a good cordless drill/driver and a set of these:
https://www.homedepot.com/p/DEWALT-3...2542/100495100
I have them in 1/4", 3/8" and 1/2" and they are great for running a bunch of bolts/nuts down finger tight before you torque them.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
new2subaru (06-15-2018)
Recomend torque wrench jflogerzi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 06-08-2017 06:38 AM
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 04:02 PM
torque wrench dcfr CANADA 13 05-15-2014 01:28 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 12:46 AM
Torque Wrench options FRiSson Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 03-14-2013 02:29 PM
