Old 11-24-2015, 07:29 AM   #1
kharn83
Drives: S15 Silvia
Compression Test Values - Factory Specifications?
Hi Guys,
I just got my car compression tested because I saw white smoke coming out the exhaust once or twice, issue seems to be resolved but I got a compression and leak test anyway.
Compression test came back 193, 197, 208, 198 (PSI)
Leak down returned less than <5% across all cylinders..
Just wondering if anyone knows what are the factory specified compression values?
E.g. New from factory = 210-230 PSI range,
Engine in serviceable condition = ... 170PSI+?
Thanks in advance guys
Rob
kharn83 is offline   Reply With Quote
Old 11-24-2015, 09:13 AM   #2
celek
Resident Gear Head
celek's Avatar
Previous engines I have had at 12.3:1 were around 210-215 and that was after 60k Miles. I would expect some issues at sub 200 on an engine with less mileage.
celek is offline   Reply With Quote
Old 11-24-2015, 09:21 AM   #3
stugray
Drives: 2013 GBS BRZ Limited
Funny that atmospheric pressure at sea level is ~15 PSI.
CR of 12.5 means 15 X 12.5 = 187.5 PSI.
That should be the highest static pressure you can get unless cranking the engine with the starter gives you a dynamic CR higher than 12.5 (not likely).
Old 11-24-2015, 09:23 AM   #4
celek
Resident Gear Head
celek's Avatar
Or my $15 compression gauge from Autozone is not accurate
Old 11-24-2015, 09:29 AM   #5
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
When I compression tested an s2000 my buddy was buying it came out around 220.
When you compress the air, it heats up, which further increases the pressure even more than just mechanically reducing the volume. The higher the compression ratio, the more heat adding to the pressure.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
Spartarus (11-25-2015)
Old 11-24-2015, 09:39 AM   #6
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
[Pedantic]Sea level 14.7. And TDC pressure equation is 14.7X(12.5^1.3x).
Although, since throttle bodies are closed and Engine is running at ~200RPM on the starter, it is tough to know the manifold absolute pressure without logging.[/Pedantic]
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 11-24-2015, 09:52 AM   #7
celek
Resident Gear Head
celek's Avatar
I also compression tested my engine at Operating temp could also be a factor.
Old 11-24-2015, 01:53 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by 200hp/tonne View Post
[Pedantic][/Pedantic]
Totally unrelated but i cant pass it up, lol
[ame="http://m.youtube.com/watch?v=yetwdpsiM8Q"]http://m.youtube.com/watch?v=yetwdpsiM8Q[/ame]
Old 11-24-2015, 02:27 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showthread.php?t=8374
Old 11-25-2015, 01:56 AM   #10
kharn83
Drives: S15 Silvia
Originally Posted by mav1178 View Post
Thanks, had a look at the engine manual couldn't find any references to comp test values.. I guess around 200psi is from factory new..
Old 11-10-2017, 12:53 AM   #11
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
So does anyone know what the values should be, with sources? Or is the 200 psi just from filtering the forum?
BaBaFlyingSheep is offline   Reply With Quote
Old 11-10-2017, 01:34 PM   #12
mav1178
mav1178's Avatar
Two posts above yours is a link to the FSM.
Old 11-10-2017, 01:51 PM   #13
mrspindlelegs
Drives: 2014 Scion FR-S Monogram Series
Is that what the service manual calls for during the test on the twins? When I turned a wrench for a living back in the 1980s, the throttle was always set at wide-open during a compression test.
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit.
Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg
Semi-truck crushed it on 1-1-2023.
mrspindlelegs is offline   Reply With Quote
Old 11-13-2017, 01:48 AM   #14
BaBaFlyingSheep
Not in the FSM, that's basically what Kharn was saying in the post above. He looked thru it already.
Requesting OEM Clutch Line Specifications RJasonKlein Engine, Exhaust, Transmission 6 05-21-2015 12:06 AM
TRD GT86/AERO Specifications 1904 Cosmetic Modification (Interior/Exterior/Lighting) 8 11-06-2014 02:03 AM
BRZ Values Apex_BRZ BRZ First-Gen (2012+) — General Topics 20 10-16-2014 05:38 PM
front and rear fender well specifications PineappleFriedRice Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-22-2013 06:06 PM
