Old 06-05-2018, 10:26 PM   #1
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
AC Delete not as much weight as advertised
Read in Anthonys post where he saved about 30lbs removing AC & components .
Just did this today using the Raceseng AC delete pulley kit which is very nice but I only saved about 15lbs
Here is the Raceseng kit about ~2.25lbs very light and very well constructed
Here is the AC compressor ~9.75lbs
Here is the AC radiator and all the underhood piping ~7.25lbs
installed pics
Gives me a net weight loss of 14.75lbs not as much as expected
At looks like Anthony counts all the vents and motors underneath the dash.
Is there another AC component under the Dash I can take out that not hurt the ability to use the heat?
SuperTom is offline   Reply With Quote
Old 06-06-2018, 12:17 AM   #2
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
The a/c piping will go into the dash into an evaporator core. Looks similar to the condenser.
I'm also assuming the refrigerant weighs something.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 06-06-2018, 12:34 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Did you see the pic? I have no idea what I'm looking at but it might lend a clue.
https://www.ft86club.com/forums/atta...1&d=1425246471
Old 06-06-2018, 08:11 AM   #4
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Yep, that white plastic part that the condesor core is leaning against in the scale picture is the under dash blower/evap core/heater core complex. It weights a fair amount, and then there are the vents in the dash, the tubing under there, etc. Removing all of it nets the full amount.
Joesurf79 is offline   Reply With Quote
Old 06-06-2018, 08:21 AM   #5
SuperTom
SuperTom's Avatar
Originally Posted by Joesurf79 View Post
Yep, that white plastic part that the condesor core is leaning against is the under dash blower/evap core/heater core complex. It weights a fair amount, and then there are the vents in the dash, the tubing under there, etc. Removing all of it nets the full amount.
That condesor is the one I pulled from in front of the radiator it has the same brackets. So everyone is saying there is another one under the dash?
I watched his youtube video and I only see him pulling the big white dash vent setup I don't see another condesor [ame]https://www.youtube.com/watch?v=Hh1uPEurKIA[/ame]
I want to keep my heatercore/vents all that intact for the winter
Old 06-06-2018, 08:42 AM   #6
Joesurf79
Joesurf79's Avatar
The refrigerant condenses in the core in front of your radiator, gets compressed by the compressor, then evaporates in the evaporator core under the dash. This evaporation action takes latent heat to accomplish, thus it gets the evap core cold. Blow air through it - vioala! Cold AC air. So yep, there is a core in that white box motor/vent piece Anthony pulled.
If you removed the lines completely from under hood, then you unbolted the bulkhead connector to the evap core that lives in the box he removes in the video.
Old 06-06-2018, 09:12 AM   #7
SuperTom
SuperTom's Avatar
Yes I saw the bulkhead connector coming out the firewall. Not ready to tear out the whole dash right now but If I have a reason I will get to it. Then reinstall the remaining vents and heatercore
Thanks everyone
Old 06-06-2018, 11:06 AM   #8
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
If you are keeping the heater and the fan, vents and ducts for it, you will not see a significant weight improvement. The evaporator itself is less than 2 pounds. It's likely about 1/2 the weight of the condenser under the hood.
PhyrraM is offline   Reply With Quote
Old 06-06-2018, 01:01 PM   #9
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I had the same weight gains like you. I am not willing to take the dash apart and the heater is fully functional. Is this white box under the dash only for the AC? I would assume that it necessary for the heater too.
Old 06-06-2018, 01:17 PM   #10
Joesurf79
Joesurf79's Avatar
It holds the blower motor so it's necessary for heater function as well, yep. as well as switching which vents are blowing air, etc.
Old 06-06-2018, 01:22 PM   #11
SuperTom
SuperTom's Avatar
Yeah the front one which should be bigger was about 3-4lbs. I am going to leave it alone.
It should be labeled
AC Delete - 15lbs
HVAC Delete - 30lbs
Old 06-06-2018, 01:54 PM   #12
SuperTom
SuperTom's Avatar
One last question. We have 2 fans upfront one should be for cooling/overheating purposes the other should turn on when the AC is turned on? I would like to find out which one is for the AC that could be some extra weight maybe 5lbs?
Old 06-06-2018, 02:08 PM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It looks that 45121*A is needed and 45121*B is only for the AC model, but I never removed it.
45121*A:
Old 06-06-2018, 03:53 PM   #14
SuperTom
SuperTom's Avatar
45121*A:
So it looks like the driver side one could go which is great since the weight would come off the heaviest side.
I went outside to test and both my fans kick on with the AC button pressed.
DIY my version Rear Seat Delete ~$60 Weight Reduction 27.5 lbs SuperTom DIY (Do-It-Yourself) Guides 29 10-25-2022 12:45 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
Weight of your brz/frs NYCsubaruBRZ NY / NJ / CT / PA 5 02-12-2014 07:11 PM
WTB: Berks dual tip muffler delete and cat delete pipe Black86 Want-To-Buy Requests 0 09-27-2013 09:31 PM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 04:20 PM
