Old 06-05-2018, 05:39 PM   #1
Hyperian
Drives: BRZ 2014
how to program new key fob?
I have a new OEM key fob from the dealership and they say it will cost $100 to reprogram the key fobs, is there anyway I can reprogram it myself or do I just have to pay them? I have a 2014 limited brz.
Hyperian is offline   Reply With Quote
Old 06-05-2018, 11:14 PM   #2
TM
TM's Avatar
Drives: DGM BRZ 6MT
Wow, Subaru reprogrammed my ‘13 keyfob for $15
TM is offline   Reply With Quote
Old 06-06-2018, 08:34 AM   #3
ermax
ermax's Avatar
I don't know about Subaru but on the Toyota it's all done with Techstream and it's super easy. The dealers are scamming people for charging so much to pair these things.
Old 06-06-2018, 09:49 AM   #4
Imrac
Drives: 13 SWP BRZ Prem
You should be able to do it with Techstream.
I remember my '08 Subaru Legacy was like:
Get in the driver Seat
Make sure all doors are closed
Within 45 seconds, open and close the drivers door 1 time
Within 15 seconds, turn the key from lock to on 10 times
Sound will chime
Open and close drivers door once
A Chime will start for 30 seconds
Before the chime stops press the power door lock button the same number of times as the first digit (of 8) of the transmitter code
When finished entering the number, press the unlock button within 5 seconds
Repeat for all other digits
Then Press the unlock button 1 time
Then Repeat entering the 8 numbers AGAIN using the same method as above.
A tone will sound, After tone ends, Start the vehicle,
then turn off
remove key
open and close door
I don't know if the BRZ has any similar stupid way of programming without techstream.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 06-19-2018, 10:52 PM   #5
Decep
Drives: 2013 FR-S Series 10
lol my dealership wanted $250 to program, and almost $400 for a new key fob. ridiculous.
Program Car Key? PNW-BRZ Electronics | Audio | NAV | Infotainment 34 01-16-2023 06:23 PM
Help! No one can program my key Dennett_ Issues | Warranty | Recalls / TSB 12 09-29-2017 08:24 PM
EcuTek Program Kit 250!!! TurboToyota Engine, Exhaust, Bolt-Ons 2 03-19-2017 10:09 PM
Possible Trading Program? ButtonMasher Miscellaneous 4 07-30-2014 01:25 PM
Scion IFI program RitualOfTheSloth Scion FR-S / Toyota 86 GT86 General Forum 0 06-11-2014 03:39 AM
