Old 06-01-2018, 01:13 AM   #1
Devin11498
Devin11498's Avatar
Drives: 2013 Subaru Brz Limited
Exhaust Leak?
I just recently installed tomei uel headers on my brz. I have check every connection and still feel like I have a exhaust leak. I took my car to a friend that works at Subaru and we put it on the lift. we sprayed the connection with soapy water and couldn't find a thing. One thing that still has me thinking I have a exhaust leak is that my cold starts aren't really that loud? I am running tomei uel headers, Invidia catless unresonated front pipe, and Invidia n1. witch this set up shouldn't my cold starts be stupid loud? I mean when I drive its loud but my cold starts aren't. could this mean I have a leak somewhere?
Devin11498 is offline   Reply With Quote
Old 06-01-2018, 01:19 AM   #2
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Why do you feel you have an exhaust leak? Do you have a video?
Do you have a tune? My Delicious tune has the loud cold start tuned out. I believe OFT does that too, but I've never personally used them. That could explain the not-so-loud cold starts.
mistople is offline   Reply With Quote
Old 06-01-2018, 04:07 AM   #3
classybum
classybum's Avatar
Drives: 2013 Asphalt FR-S
Perhaps it wasn't actually a cold start? What were your RPMs after start? If your weather is anything like the 90 degree days we've had in Chicago this week, it may not have been a true cold start.
Sent from my SM-G920V using Tapatalk
classybum is offline   Reply With Quote
Old 06-01-2018, 02:12 PM   #4
Devin11498
Devin11498's Avatar
our wweather here in SC has been around 80 to high 80's. I always figured all cold starts should be loud no matter what bc the pipes are cold. Since its pretty hot weather could that be why my cold starts arent that loud? my rpms sit at like 1.5k-1k area.
Old 06-01-2018, 02:14 PM   #5
Devin11498
Devin11498's Avatar
yes i am currently running the oft stage 2+ tune.
Old 06-01-2018, 02:38 PM   #6
humfrz
It could be that the aftermarket header just sounds louder, because most are made of thinner material that the stock header ……..
Like mentioned, and I'll guess, that the tune has quieted down the cold start sounds.
humfrz
Old 06-01-2018, 06:05 PM   #7
tyler_win_photo
tyler_win_photo's Avatar
When you rev do you hear an exhaust leak? It's a very distinctive sound. Just because your cold starts aren't loud doesn't mean there's a leak. Like others have said it might just be your tune or the temperature.
tyler_win_photo is offline   Reply With Quote
Old 06-01-2018, 06:10 PM   #8
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
I would think a leak would be loud....You are probably fine.
22R
22R is offline   Reply With Quote
Old 06-02-2018, 08:13 AM   #9
classybum
classybum's Avatar
I have a oft, running older maps, probably v2, and it didn't disable my cold start. The loud noise is from timing adjustments, not cold pipes.
I'm thinking maybe your N1 already gave you all the volume you're going to get?
Old 06-02-2018, 08:15 AM   #10
classybum
classybum's Avatar
Oh and when I put on my headers, I had an exhaust leak. Small one, couldn't hear it, but I'd smell exhaust at stop lights. It also caused really rough starting on the ots stage 2 e85 tune
Old 06-02-2018, 10:29 AM   #11
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
The new OFT Tunes (Stage 2+ is from the newest version) have the cold start disabled
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 06-02-2018, 05:20 PM   #12
NyX_Nick
Drives: 2013 WRB BRZ Stock, 1991 Toyota MR2
If you're running OFT V4 tunes, they all have cold start disabled, that's why your car isn't loud at startup anymore. The coldstart is there simply to heat up the cats faster, with no cats, there's no need. So it's disabled.
NyX_Nick is offline   Reply With Quote
Old 06-02-2018, 09:44 PM   #13
NRXRaptor
when did the v4 tunes come out? I got my oft in october and my cold starts are loud as fuck
NRXRaptor is offline   Reply With Quote
Old 06-02-2018, 09:54 PM   #14
NyX_Nick
March according to the thread in the Software tuning section. I think they're still considered "Beta" tunes though, so you'll need to download them from the site and then upload them to the OFT manually
Sent from my CLT-L04 using Tapatalk
Possible exhaust leak? dar3d3vil Engine, Exhaust, Transmission 10 02-21-2016 07:45 PM
Exhaust leak? Joeycokeboy Engine, Exhaust, Transmission 6 06-05-2015 12:29 PM
Exhaust leak? Jman1759 Engine, Exhaust, Transmission 4 11-29-2014 11:11 PM
Exhaust Leak help? ray7792 Engine, Exhaust, Transmission 4 07-04-2014 01:08 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
