Old 05-30-2018, 10:27 AM   #1
671mike
Drives: 2015 frs
FRS/BRZ ELECTRONIC BOOST CONTROL
looking to get a boost controller for my frs but don't know what one to get I like the grimmspeed one but don't know what one I need any suggestions
thanks
671mike is offline   Reply With Quote
Old 05-30-2018, 03:14 PM   #2
mrloko
Drives: 2017 Subaru BRZ
Delicious tuning sells an EBC, they're pretty reputable and they can tune it for you as well
mrloko is offline   Reply With Quote
Old 05-30-2018, 04:51 PM   #3
I use Delicious.
Old 05-31-2018, 10:15 PM   #4
Turbo
Drives: FR-S Turbo
Can an Ecutek re-programmed factory ECU run a boost controller? Or does that job need to be done by a stand alone controller?
Turbo is offline   Reply With Quote
Old 06-03-2018, 06:50 PM   #5
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
DIY
Let me count the ways:
Get this pin and plug kit:
https://www.bmotorsports.com/shop/pr...oducts_id/3510
Get this solenoid bracket and barb kit or something like it:
https://www.ebay.com/itm/GENUINE-MAC...UAAOSwcJ1a7M8J
Crimp the pins to the wires on the solenoid and go to lowes to find some machine hardware that fits the bracket (bolt, teflon nut, washers, blue loctite everything together). You may need to drill the bracket out slightly to get the solenoid to sit further away from the AC line (or just bend it up a little, not a big deal).
$50 or so you diy'd your own boost controller.
Not super polished but here's one I made:
elitegunslinger is offline   Reply With Quote
The Following User Says Thank You to elitegunslinger For This Useful Post:
Joveen (08-05-2020)
Old 06-03-2018, 10:47 PM   #6
steve99
If your going to go electronic boost control your better off just going with ecutek tune system as it can use the standard ecu to control the boost control solenoid/valve directly.
you could use an external boost controller but this would end up being more expensive and complex than just going ecutek tune system.
Old 06-05-2018, 07:07 PM   #7
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
Originally Posted by elitegunslinger View Post
DIY
I actually used the EVAP solenoid extension harness already in the car to wire in the EBC. Works great
kimcheefists is offline   Reply With Quote
Electronic Boost Controller BRZtoni Forced Induction 9 01-21-2018 02:38 PM
electronic boost control. Jaden Forced Induction 10 02-02-2015 12:28 PM
Electronic Boost Controller Issues 1BadFA20 Forced Induction 1 06-09-2014 02:21 AM
