Old 05-29-2018, 04:15 PM   #1
apatel471
apatel471's Avatar
Drives: 2017 World Rally Blue BRZ
LED front turn signals and Valenti tailights
This is my first post on here
I am looking to upgrade the front turn signals to LED's and taillights to Valenti sequential ones.
If I were to install a hyperflash-fix flasher under the dash, how does it affect the sequential function of the taillights?
- Does it prevent the tail light turn signals from fully "extending"?
If the flasher would mess with the rear tail light sequential function would I need resistors, and if so which wires to tap into(for the front turn signals)or would the front not hyperflash?
apatel471 is offline   Reply With Quote
Old 05-29-2018, 04:48 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I don't have experience with Valenti sequential tail lights, but an electronic flasher is no different from the stock flasher. It just uses electronics to control the on/off current flow to the turn signals, as opposed to a mechanical mechanism. At the end of the day, the tail lights still see the same current, for the same amount of time (give-or-take any slight difference in the rate at which the specific module you purchased flashes.)
TL;DR, I don't think it would affect the sequential function of the tail lights, but I'm also just guessing based on my limited knowledge of how it operates. I'm sure you can get a better answer from someone with those actual lights.
/kinda-sorta-useless-reply
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-29-2018, 04:51 PM   #3
Kaotic Lazagna
Drives: GR Corolla
I sold my neighbor my switchback LEDs for the front. He has the sequential rear taillights, and he told me that the rear turn signals will only go halfway before restarting. I'm not sure if that's because it is a switchback style, or simply being LEDs in the front. He just switched it to non-sequential turning.
Old 05-29-2018, 06:09 PM   #4
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
The sequential works perfect with the hyperflash-fix. Sauce: I run sequential, diode dynamics led front turn bulbs, and the box under the dash.
Without the hyperflash fix, the turn signal cycles too fast for the sequential to keep up.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 05-29-2018, 06:29 PM   #5
carlovestela
Drives: 2015 Firestorm FRS
Is the quality good for the switchback front turn lights?
Also planning to install toms tail lights. Will i have to put 2 relay flasher?
carlovestela is offline   Reply With Quote
Old 05-30-2018, 11:36 AM   #6
LED86
LED86's Avatar
Drives: Black 86 GTS
You need need an led relay to stop the hyper flashing caused by the front led indicators. The Valenti has built in resistors so don’t need a relay installed to function. The reason why the other post was only getting half the sequence on the tail lights is because the front led was causing hyper flash and so the sequence of the tail lights is too rapid to do the full sequence. Again just needs an led relay and only one.
LED86 is offline   Reply With Quote
Old 05-30-2018, 12:24 PM   #7
ermax
ermax's Avatar
Those after aftermarket relays suck. Just mod the OEM flasher like this:
http://www.ft86club.com/forums/showthread.php?t=114284
Old 05-30-2018, 01:39 PM   #8
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
no complaints on my $15 relay.
fx1mark is offline   Reply With Quote
Old 05-30-2018, 01:45 PM   #9
Stang70Fastback
A.K.A. Starlord
They certainly don't "suck." At worst, depending on the one you get, the first blink might be slightly longer than the other blinks. I have a TapTurn module, and it is the exact opposite of "suck," though also not particularly cheap, either.
Old 05-30-2018, 01:54 PM   #10
fx1mark
fx1mark's Avatar
And I couldn't care less that the first blink might be slightly longer than the other blinks.
Old 05-30-2018, 04:32 PM   #11
ermax
ermax's Avatar
The delay on first blink is exactly why I say the aftermarket ones suck. You can pull the OEM blinker, desolder the shunt resistor and solder in a new one for about $0.10 and still maintain the burnt bulb detection (something the aftermarket relays don't do) and not have that annoying lag on the first flash.
Old 05-30-2018, 09:25 PM   #12
LED86
LED86's Avatar
Valenti make a relay that don’t have the first flash delay and also has tap to turn.
https://led86.com.au/collections/86b...-flasher-relay
Old 05-30-2018, 09:49 PM   #13
Stang70Fastback
A.K.A. Starlord
If you're going to spend that much money, you might as well get the actual Tap Turn flasher, which does a LOT more stuff.
www.autowindow.com
Here's a video I made to demmonste some of the features on my car (the approach and departure function was disabled during this demo.)
[ame]https://www.youtube.com/watch?v=18w39RmVZjY[/ame]
Old 06-01-2018, 10:11 AM   #14
LED86
LED86's Avatar
Your right if your in the states, you don’t see tapturn in oz.
2015 OEM Headlights, turn signals, side markers, reverse light, & Valenti tail lights Vinsanity091 Exterior Parts (Aero, Lighting, Etc.) 4 06-11-2017 05:56 PM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
switchback turn signals with toms tailights Celigts Cosmetic Modification (Interior/Exterior/Lighting) 9 02-18-2015 11:51 PM
WTB: Front turn signals (FR-S) sirsol66 Want-To-Buy Requests 2 12-16-2014 03:20 AM
smoked front turn signals dawnst3ar Cosmetic Modification (Interior/Exterior/Lighting) 20 05-21-2013 08:17 PM
