Old 05-29-2018, 05:03 AM   #1
Hags86
Drives: Toyota GTS 86
Engine internals for 500-600 HP turbo
Hi All
Looking to make 500-600 engine horsepower on a GTX3582R platform.
Currently running a smaller turbo on stock internals making 241 rear wheel kW (probably just on 400 engine HP) on e85. Just bent a rod so now will build the engine and put on a larger turbo.
Intended use is daily driving and track days. Will be retired to be a track-only car in the near future. Am not planning to drag race it.
Components I already have:
- Motec M150
- stock DI
- bosch 1050cc port injectors
- flexfuel sensors. Will run e85 all the time unless in an emergency and just need to get home. Appropriate fuel pumps and surge tank etc.
- Holinger sequential, LSD, brakes, suspension etc all sorted.
Parts I've decided on:
- JE 10.5:1 86.5mm pistons
- ARP head studs (Custom Age if possible, else S2000)
- ARP S2000 main block studs
- Brian Crower I Beam with Custom Age fasteners unless I can find Pauter in stock at a good price.
To be sourced and looking for ideas:
- valve, spring and valve guides. Do I even need to do this based on my HP goals or stay with stock? Rockers?
- gaskets. Leaning to OEM
- recommendations on whether to do a closed deck. Overkill? Will it add longevity or is it just unnecessary?
- what are people doing for oil pumps and getting some more pressure at high revs?
I'm based in Melbourne Australia but will be in the US next week. Hoping to grab it all as a package whilst I'm there. This stuff is damn expensive in this hemisphere....
Hags86 is offline   Reply With Quote
Old 05-29-2018, 06:41 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
500 hp you say, well to be honest it could be done but, with that kind of power goals your better off doing a V8 swap & super/turbocharged.
At the end of the day you'll be spending the same amount of money.
Unless you want to drop down to a nice 300-350hp, for our platform it's easily attainable and track proven.
Old 05-29-2018, 09:43 AM   #3
StraightOuttaCanadaEh
Wes
Don't forget a gear set as well, or at least a spare transmission sitting around when the existing one goes.
Instagram: @gt86ws
Old 05-29-2018, 09:54 AM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
GSC beehive springs, OEM gasket set, L19 or 625+ head studs. Main studs are not that big of a deal on these motors. King rod/main bearings. reimax oil pump gear
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
CxG (06-11-2018), glorydays (11-12-2020), Hags86 (05-29-2018)
Old 05-29-2018, 03:04 PM   #5
Hags86
I have a close ratio Holinger sequential gearbox from a V8 Supercar. I think I'm good.
The Following User Says Thank You to Hags86 For This Useful Post:
Detroiter (05-30-2018)
Old 05-29-2018, 03:06 PM   #6
Hags86
Do you have a part number for the 625+ head studs? The only ones I can find are for a WRX/FA20DIT and I don't know if they fit the FA20.
Old 05-29-2018, 05:10 PM   #7
mrg666
pessimistic skeptic
mrg666's Avatar
I don't know any daily driven twin at that power level. All of them are constantly being fixed or they are already dead. It is not worth it. Get a Corvette.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
Mr.ac (05-30-2018), Somerandom18 (05-29-2018)
Old 05-30-2018, 09:14 AM   #8
Hags86
Is this the high capacity Reimax oil pump or just the replacement pump gear?
Old 05-30-2018, 10:11 AM   #9
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
If Hags wanted a corvette he would have bought a corvette, did he ask for you're opinion on whether he should do it or not? No. Opinions are like assholes everyones got one.
Show me facts that a 500chp twin can't be daily driven if done with quality components and most importantly a top notch tune. 500chp is only about 425whp. Some have run around 400whp on stock blocks for a decent amount of time(obviously others have blown the engine) but for a built motor that seems well within the attainable level. It's not like the guys going for 700whp.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 05-30-2018, 11:40 AM   #10
mrg666
pessimistic skeptic
mrg666's Avatar
LOL, you have very strong feelings about this 500hp, huh? I am sure you are not getting there with that HKS filter you cared to write as a mod though.
I can express my opinion wherever I want and I think I am a little closer to 500hp than you to talk about it.
I would buy a Corvette if I wanted a 500hp sports car. This car would never be as a good as a Corvette with that much power. Here, wrote again just for you.
Old 05-30-2018, 03:04 PM   #11
I'm pretty close to 500hp too.
I wouldn't want a Vette, because a Vette will never be as light as a 86.
The Following 9 Users Say Thank You to CSG Mike For This Useful Post:
Alltezza (05-31-2018), ATL BRZ (06-01-2018), CxG (06-04-2018), Detroiter (05-30-2018), DriftinFRS (06-13-2018), glorydays (11-12-2020), jeepmor (04-30-2021), JoeC (05-30-2018), toast (05-31-2018)
Old 05-30-2018, 03:36 PM   #12
mrg666
pessimistic skeptic
mrg666's Avatar
I wouldn't want a Vette either. But don't you think a little more weight with that much power would be more stable and give you better traction?
Old 05-30-2018, 03:53 PM   #13
Traction isn't an issue for me. Using weight to get traction hurts performance in other areas (cornering, acceleration, consumable use/wear, etc.).
If weight equated directly to traction and performance, manufacturers wouldn't be fighting to reduce the weight of their cars!
Old 05-30-2018, 04:31 PM   #14
mrg666
pessimistic skeptic
mrg666's Avatar
Good, if somebody can properly build and drive a 500+ hp twin, it would be you. For me, as I wrote before, I wouldn't try.
GReddy T620z Turbo Kit -- save $1500 over retail! 350 WHP on e85 STOCK INTERNALS ZeroTo86 Engine, Exhaust, Bolt-Ons 5 08-11-2016 09:36 PM
Engine Internals from CP-Carrillo Now Available! Infamous Performance Engine, Exhaust, Bolt-Ons 108 02-13-2014 11:35 AM
THEY'RE HERE!! ENGINE INTERNALS // DSG PERFORMANCE Jason@DSG Engine, Exhaust, Bolt-Ons 18 01-14-2014 11:15 AM
Max power for factory drivetrain and engine internals solidONE Forced Induction 64 09-23-2013 01:16 PM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 05:18 PM
