Old 05-27-2018, 01:39 PM   #1
gtpvette
Drives: 2015 FRS - FFR GTM
FRS Alternator Plug
Any of you guys wiring up the FRS Alternator plug?? If so,,, how?? It's A43, purple, orange and blue with red stripe??
Thanks!!!!
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 06-13-2018, 03:36 AM   #2
AmorAutosport
AmorAutosport's Avatar
Drives: 2015 FRS
Look up wiring for a 3-wire alternator. There’s usually.
Field (FR) that goes to a switched +12v source
Signal (S) which is going to a +12v source with high load, I usually wire it to a fuse block, basically this wire is what tells the alternator what the current power is so it can regulate voltage.
Lamp(L) here you would put a charging diode with the negative end to lamp and the positive end tied into +12v switched power I typically use the FR wire. Without this the alternator will never charge
AmorAutosport is offline   Reply With Quote
Old 06-13-2018, 03:38 AM   #3
AmorAutosport
Drives: 2015 FRS
The frs alternator is probably the same as the sti/wrx which I have the wiring for, the colors might not be exactly the same.
My alternator dying? stockysnail Electronics | Audio | NAV | Infotainment 26 08-17-2021 02:23 PM
WTB alternator FTA_Dave Canada Classifieds 1 04-24-2018 10:51 PM
How will I know I need an alternator upgrade? driftking96 Electronics | Audio | NAV | Infotainment 3 06-22-2016 08:47 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 09:38 PM
