Drives: 17 86
Hlep with high-frequency buzz, please!
Been there for a while on certain types of road surface. No buzz on nice smooth new roads, buzz on well-used roads.
It's a high-frequency buzz that I thought was coming from the speaker area, or maybe from the mirror area, or behind the instrument cluster. I just discovered, though, that if you have any pressure at all on the gas pedal it sops buzzing. Off-throttle, buzz. Any pressure, no buzz. For whatever reason, I can't get the https://demos.starbase7.net/ page to load. Any ideas as to what it might be and where to look? Thanks! |
Drives: 2015 FR-S
Mine did it for a couple years but it eventually went away. It was almost like the sound a bee would make buzzing inside an envelope...not that I put bees in envelopes for fun or something.
I could hear it only with windows up and driving at about 45+ mph on a smooth round and it sounded like it came from instrument panel or speakers by window. It never bothered me enough to really look for it since 99% of the time, I have the windows down but maybe try driving with a passenger to keep a look out as you get it to reproduce the sound and touch different areas to make it stop. |
High pitched sound
When you get older, it will go away .. ![]() humfrz |
Heat shield? Mine dies the same since. I went through a big puddle. Haven't went on a quest to see what it is but pretty sure it is one of the heat shields. Had it before on other cars and sounds the same.
Drives: 17 86
Thanks, all. I sill can't get to the tech doc site. Could one of you try, and if you can get in, post the throttle linkage stuff?
#6 | |
Is this where you wanna go .. ?? https://demos.starbase7.net/t3Portal/ humfrz |
#7 | |
Drives: 17 86
#8 | |
https://demos.starbase7.net/t3Portal..._rm_index.html If that don't work, you might try a different browser and/or refresh the page. humfrz |
#9 | |
Drives: 17 86
iPad and Android tablet time out as well. Must be my connection, but everything else is good. |
#10 |
not playing cards
There isn't much to it. A couple M6 nuts.
#11 | |
![]() That sound may be that sonic sound torture, they have been suspected of using .. ![]() humfrz |
#12 |
Drives: 17 86
#13 |
You might check to see if something is lose that attaches to the inside of the firewall. Something that would vibrate when the engine is NOT torqueing over
![]() humfrz |
#14 |
not playing cards
For the gas pedal, yeah. It could be a bajillion things, though. You mentioned the speaker grill. A-pillar cover? Clutch/brake pedal assembly where it attaches to the chassis? The return spring inside my clutch master would rattle occasionally. That one was brutal. Sounded like a spun rod bearing until I learned to just barely tap the clutch pedal. Freakish.
| Hlep. I failed. | Shaisters | Northwest | 14 | 06-02-2016 10:56 PM |
| Slight buzz at 1,500 RPM | ericmpena | Engine, Exhaust, Transmission | 5 | 05-02-2014 08:35 AM |
| Would coaxial door speakers plus stock tweeters be too much high frequency sound? | Prog | Electronics | Audio | NAV | Infotainment | 4 | 12-27-2013 07:15 PM |
| Anybody Have this Buzz/Rattle? | Gary in NJ | BRZ First-Gen (2012+) General Topics | 8 | 10-07-2013 12:36 PM |
| Help with high frequency rattle | tomkozski | Issues | Warranty | Recalls / TSB | 10 | 08-27-2013 08:56 PM |
