Old 05-24-2018, 09:35 AM   #1
Roxas93
Roxas93's Avatar
Drives: Toyota GT86
Tune file for turbo's GT86
Hi dear, please can sameone share his tune file? Doesnt matter It has made with ecutek, ecuflash etc... The only thing I want is that the file has ti benedica for turbo's GT86/brz Car, don't care if It is sbd, greddy or other turbo's kit. All' turbo kit tune file are ok for me
I Need this file very urgently
Roxas93 is offline   Reply With Quote
Old 05-24-2018, 11:54 AM   #2
Conti93
Conti93's Avatar
Drives: '02 Speedster n°586 - '23 GR86
Here are some base maps for the SBD turbo kits: http://www.ft86club.com/forums/showp...21&postcount=1
These are US maps, but you can open them with the appropriate definition on RomRaider et similia.
p.s. Io scriverei a Giovanelli
Conti93 is offline   Reply With Quote
Old 01-09-2021, 02:58 PM   #3
Pippoemme
Drives: Toyota GT86 2016
hello,
I've tried to open the A01C tune with the definitions file released by OFT but it did not work: many error messages popped up during the tune opening phase (e.g. ... table editing disabled, tune or ROM image may be corrupted .... ) and after the file opening was complete the tables inside where quite wrong (strange random numbers jumping up from a cell to the neghbouring cell and then going back in the next cell, and so on....).
I believe it is because the definition file from OFT is v4 version while the tunes of yeat 2014 required previous OFT definitions, do you think it is possible ? Just in case, can someone provide the older version definitions for the A01C code?
Many thanks in advance,
Giuseppe
Pippoemme is offline   Reply With Quote
Old 01-09-2021, 05:03 PM   #4
steve99
Originally Posted by Pippoemme View Post
hello,
Giuseppe
Open the tune with a hex editor search for ZA1J there should be three calid in rom check they are all A01C if they are use the romraider A01C definition from romraider below
https://github.com/TD-D/SubaruDefs/t.../RomRaider/ecu
Old 01-12-2021, 07:41 PM   #5
Pippoemme
Many thanks Steve99, it worked fine, wonderful !!
Is there a OFT tune file for ZA1JK00C xeroshoes Engine, Exhaust, Transmission 1 11-02-2017 12:46 AM
OFT Failed to Write - Tune File Erased Danklvr Software Tuning 5 09-08-2017 07:26 AM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 03:26 PM
Can I map access in ECUtek without a tune file? Cal3000 Software Tuning 11 10-14-2013 07:26 AM
DI Popping noise, just installed new updated tune file. Bg8780 Issues | Warranty | Recalls / TSB 21 06-27-2013 11:56 PM
