| Engine Swaps Discussion of engine swaps. |
Drives: GT86 Nur spec
2jz problems
i just did a 2jz swap and im facing a problem with the power steering and i also have a motec installed. i checked the wiring, harnesses ..etc nothing worked can someone please help me and tell me what is the easiest way to do it?
__________________________________________________ __________________________________________________ ___________________ Engine: Injen intake, borla catdelete frontpipe & overpipe, eibach pro lowering springs, 30&25mm H&R spacers, torque solutions throttle spacer. Exterior: Blackout oem taillight, Nur spec body kit Interior: kenwood headunit, full audio system, full carbon fiber overlays Last edited by Diz86x; 11-10-2016 at 06:06 AM. |
Who did your wiring? Are you running the 2jz/frs license? If not, who did you programming? I'm pretty sure you won't find this answer on this forum and it's best left for your programmer/tuner and/or your wire guy.
| Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-04-2016 11:18 PM |
| ECU problems | cwilson | Issues | Warranty | Recalls / TSB | 4 | 04-14-2016 10:01 PM |
| AT problems? | AJPG | Engine, Exhaust, Transmission | 8 | 03-08-2015 06:50 AM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
| No CEL problems here | BRZranger | Issues | Warranty | Recalls / TSB | 41 | 12-08-2012 01:36 PM |
