Old 05-21-2018, 07:15 PM   #1
Jetyn
Drives: 2013 Subaru BRZ
Exclamation Assistance Requested
My dumb self shorted out the main fuse connected to the battery while installing struts, replaced it 2 days later and nothing is working for the most part. Attaching the left part to the main fuse lets me be able to unlock my car or lock it just to check if power is going through but after one click of the lock or unlock it dies out and im not able to do anything, no lights on my dash, nothin works.
Help is greatly appreciated. Thanks!
P.S. Its disconnected bc me trying to fix it and yes i’ve tried with everything tightened.
https://imgur.com/a/xAqEi04
Jetyn is offline   Reply With Quote
Old 05-21-2018, 10:03 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds to me like there is another blown fuse somewhere
Not going to ask how you managed to short out a battery when installating struts... or maybe it would help?
Old 05-21-2018, 10:21 PM   #3
humfrz
Maybe the battery is run down. You might want to check it's voltage …..
humfrz
Old 05-23-2018, 10:00 PM   #4
Jetyn
humfrz
Got it fixed after jumping my car. Wouldnt think the battery would be run down after just replacing it, thanks!
However i've run into another problem where the passenger door controls don't work ( windows & lock/unlock button ). The courtesy lights aren't on, the window doesn't auto roll down when opening the door but the it unlocks and locks with they key fob controls.
I already check fuse #10 & #14, could it be a different one? And no my passenger lock button on the drivers side isn't pushed down.
Old 05-23-2018, 10:01 PM   #5
Jetyn
My battery doesnt have a cover on the positive terminal so as i was tightening the bolt for the strut things got out of hand and hist the bolt on the main fuse connected to the battery.
Old 05-24-2018, 12:24 AM   #6
humfrz
Have you checked the fuses in the cabin, under the instrument panel .. ??
humfrz
Old 05-24-2018, 02:39 AM   #7
Jetyn
humfrz
I have not, havent had the time to. I've looked up the fuse box diagram and don't see anything that relates to it all but i'll have a look at it soon
Old 05-24-2018, 07:29 AM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I would make time to check your interior box. http://www.autogenius.info/subaru-br...e-box-diagram/ and the dome light, is the switch functions itself not working? Or are you relying on door open/close to test it?
Old 05-25-2018, 01:36 AM   #9
Jetyn
It doesnt open at all, the only hing on the passenger door that works it the lock itself via my key. I’ll have a look at it in the morning just couldnt see a fuse on the diagram that describes it but i guess ill check all of them
Old 05-28-2018, 01:07 AM   #10
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Worst case scenario is that you may have internally shorted something inside the BCU, keep checking the other suggestions
Old 05-30-2018, 05:54 PM   #11
Guest
Drives: 2017 BRZ PP
Is the light on the passenger window switch blinking? May just need to relearn the window switch or whatever..
Guest is offline   Reply With Quote
DBW TQ requested table?? Grip Ronin Software Tuning 26 09-14-2020 10:22 AM
Urgent help requested on exhaust install Vdub Engine, Exhaust, Transmission 8 05-20-2017 09:13 PM
Custom seat belt pads I requested now available shiumai Cosmetic Modification (Interior/Exterior/Lighting) 85 02-19-2016 04:45 AM
Help Requested - Check out a car in Hillsboro finch1750 Northwest 9 09-25-2014 09:52 AM
Leg Motorsports Duck End Spoiler! Just as you requested. vividracing Exterior Parts - The Rest 2 12-09-2013 01:28 PM
