Old 05-17-2018, 08:55 PM   #1
carlovestela
Drives: 2015 Firestorm FRS
Installing nur spec wing
Has only 2 small holes each side
And double sided tape.
Will it be stable and will not drop off when i hit the freeway?
Thanks
http://imgur.com/a/xxTQ7sK
carlovestela is offline   Reply With Quote
Old 05-17-2018, 11:43 PM   #2
sugoi
Drives: 2015 BRZ Limited CWP
no
sugoi is offline   Reply With Quote
Old 05-18-2018, 12:08 AM   #3
carlovestela
What no?
Originally Posted by sugoi View Post
no
Old 05-18-2018, 05:01 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
no
[ame]https://www.youtube.com/watch?v=zyWz6Uz0nmg[/ame]
Old 05-18-2018, 05:15 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
I think 2 sided toupee tape should do the job.
Actually, they look a lot like WRX STI wings. I'm going to take a look in the garage...
...the bases are quite wide and stable looking. Peeking under the edge of the deck lid liner there appears to be 2 bolts per side in a 45 degree config relative to front/rear. No doubt some type of backing washer possibly with something to dampen contact with the sheet metal.
Installing/Wiring Spec-D FRS lights into my Subaru BRZ subtledriver Cosmetic Modification (Interior/Exterior/Lighting) 14 04-28-2018 01:53 PM
Installing Spoiler Authority rear wing blkwrxwag Cosmetic Modification (Interior/Exterior/Lighting) 2 06-06-2017 02:00 PM
Nur Spec GT Wing / OEM Euro Spec Wing SmireyFase Cosmetic Modification (Interior/Exterior/Lighting) 2 10-27-2016 02:03 PM
Help installing wing? MObrz5 Northern California 8 08-03-2014 01:14 PM
Need urgent help installing the Spec D headlights up and running. aznknightz17 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-16-2014 02:17 PM
