Old 05-17-2018, 12:08 PM   #1
Cebal
Cebal's Avatar
Drives: 15' BRZ Limited
Cool Subaru BRZ starting problem. Key? Immobilizer?
Hello guys. Got some serious problem here. 6 months ago I bought Subaru BRZ Limited with keyless starting feature etc. Everything was ok for 6 months untill now. 3 weeks ago It started to happen randomly. When im pressing the clutch then pushing the START button the car is starting up normally but second after it stalls. Sometimes it's starting like there is no problem at all. But for example day after it's happening again. I changed clutch safety switch for brand new one but it didn't help. Changed key battery too, nothing. I tried to change car battery, bought a new one, stronger, connected to the car and key won't even open the door when im pressing the buttons. It just doesnt even respond with new battery so switched back to my OEM old one.
Is it immobilizer related? Or maybe a key? I don't have a spare key to try tho. Do I need a new key programming maybe? Fighting with this problem for 3 weeks now. Im driving the car afraid it can happen and I will be stuck somewhere...
Video of the problem:
[ame]https://www.youtube.com/watch?v=ZtgW8D4d0G4[/ame]
Thanks in advance.
Cebal is offline   Reply With Quote
Old 05-17-2018, 12:44 PM   #2
bababooey
Drives: BRZ SWP Limited -6MT
in for solution, but seems you can rule out imobilizer since the car fires up. if key wasnt in sync it wouldnt start.
i suspect someone more familiar may mention a maf or intake issue?
Old 05-17-2018, 01:07 PM   #3
Is the car stock? Did you change anything before the problem started?
Old 05-17-2018, 01:38 PM   #4
Cebal
Cebal's Avatar
It's pretty much stock. Valenti tail lights and Invidia N1 catback both parts right after I bought it.. No other electric mods.
Old 05-17-2018, 01:56 PM   #5
rlpaul
Drives: point A to point C. Screw point B!
Does push start work?
rlpaul is offline   Reply With Quote
Old 05-17-2018, 02:04 PM   #6
Cebal
Cebal's Avatar
Yes, push start works fine, clutch safety switch works fine. Sometimes I have no problems with starting. It's kinda random...
Old 05-17-2018, 02:35 PM   #7
humfrz
Any codes showing up .. ??
Does your gas have ethanol in it .... ??
If not, you may consider adding a can of isopropyl alcohol to your gas tank, to absorb any water.
humfrz
Old 05-18-2018, 05:25 AM   #8
Cebal
Cebal's Avatar
No codes at all, fuel is fine. Today I tried to start it up and it didnt even fire up. Just lights came up like normall but no crank. My steering wheel is not locked tho. Maybe its the battery? Yesterday had it cranked and stalled but today not even a crank. Im fully recharging battery right now to check it.
Old 05-18-2018, 12:29 PM   #9
humfrz
Well, the battery sounded strong when it cranked in your video ...... however, that was a while ago.
You may wish to check the battery with a "load test".
It wouldn't hurt to clean your battery terminals and check the fluid in the battery.
humfrz
Old 05-18-2018, 01:39 PM   #10
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Battery is always a good starting point. Surprised a code hasn't been thrown though, so it can't be that bad?
majixmatrix is offline   Reply With Quote
Old 05-19-2018, 02:50 AM   #11
steve99
Thanks in advance.
I would go and get a spare key, try locksmith first. (yes I know they are expensive). but if this key dies completely you going to be in for more cost and towing to dealer. If you loose of beak all keys its more expensive then just replacing keys.
Then tackle to intermittent car stalling, it might not be related to key
Old 05-19-2018, 02:27 PM   #12
Cebal
Cebal's Avatar
Ok, a little update here guys. First of all thanks for trying to help me out with this sh*t. Today It doesn't even crank...
Yesterday I fully recharged battery and checked most of the fuses for ignition, starting system or power steering - all seem to be fine, power steering is ok, clutch safety switch seems to be fine aswell as it finds the key when I push the clutch. I'm about to check the starter or connections to the starter. I hear the 'click' but no crank. I'm guessing have to look under the car to get the starter out?
Here's the vid from today:
[ame]https://www.youtube.com/watch?v=5rCCv1U0TqA[/ame]
Old 05-25-2018, 04:23 AM   #13
Cebal
Cebal's Avatar
OK, got some code's showing up:
B27A2 : [Passenger side external antenna output stage open]
B2786 : No response from steering lock ECM
I managed to delete these codes but those 2 codes above are showing up even after I delete them:
B1011 : BATT power supply (control) malfunction
B1012 : BATT power supply (backup) malfunction
B1013 : IGN power supply failure
B1014 : ACC power failure
I checked fuse's but all are fine...
Old 05-25-2018, 01:12 PM   #14
humfrz
hmmm...……. when you turn on the headlights on, are they bright?
What voltage does your battery read?
Come back.
humfrz
Intermittent starting problem LS1M Software Tuning 4 06-12-2017 02:03 AM
Subaru BRZ With e85 Flex Fuel Kit Not Starting In Cold morswestford Engine, Exhaust, Transmission 52 05-03-2017 06:50 PM
BRZ limited odd starting problem. armstrom Issues | Warranty | Recalls / TSB 19 04-06-2016 10:21 PM
Del Sol starting problem Ashikabi Other Vehicles & General Automotive Discussions 5 03-22-2016 07:24 PM
Starting problem ricerocket93 Issues | Warranty | Recalls / TSB 5 09-06-2014 03:15 PM
