Old 03-22-2016, 06:33 PM   #1
Ashikabi
Ashikabi's Avatar
Del Sol starting problem
Ok guys, here's the symptoms. Turn key to accessory: only radio works, no dash lights or climate control. Turn key to"start": engine turns over like normal, full power to all systems. Release key from "start", goes back to "run": car looses power, immediately shuts down.
While running it can randomly die and replicate above symptoms.
It doesn't do it every time it starts.
While running it runs fine: no sputter, or loss of torque/hp.
I've had "idle air control" suggested. And the main relay. I think it has something to do with the ignition switch since the accessory power is fucked up.
Anyone have any ideas?
Old 03-22-2016, 06:52 PM   #2
Before I even finished reading my mind headed toward ignition switch. Had the issue on my Talon. Almost the exact same symptoms. You don't have a bunch of heavy stuff on the key ring do you? I think that was what wrecked mine.
Old 03-22-2016, 07:06 PM   #3
Irace86
Drives: BRZ + Ducati M796
My lancer had a problem starting because a screw holding the ignition switch got loose. Just saying
Irace86 is offline   Reply With Quote
Old 03-22-2016, 07:10 PM   #4
Ashikabi
Ashikabi's Avatar
I do have numerous keys. I thought ignition switch too. Do you suppose I need the whole switch or just the tumbler?
Old 03-22-2016, 07:17 PM   #5
Zed
Drives: 2013 Subaru BRZ Limited GBS
Not a direct solution to your problem, but highly suggest some detachable key rings for preventing the same issue in the future:
[ame="http://www.amazon.com/MoMA-Magnetic-Key-Holder/dp/B013TWHUV2/ref=sr_1_3?s=office-products&ie=UTF8&qid=1458688358&sr=1-3&keywords=magnetic+key+ring"]Amazon.com - Magnetic Key Holder -[/ame]
Zed is offline   Reply With Quote
Old 03-22-2016, 07:24 PM   #6
Ashikabi
Ashikabi's Avatar
Thanks, I didn't know they came in magnetic versions. I have one with a button but I've never detached it when driving
Intermittent starting problem LS1M Software Tuning 4 06-12-2017 02:03 AM
Starting problem ricerocket93 Issues | Warranty | Recalls / TSB 5 09-06-2014 03:15 PM
starting out dmitri93 Scion FR-S / Toyota 86 GT86 General Forum 30 07-11-2014 12:06 AM
Rev when starting ? (Possible and why ?) Simon99 Software Tuning 11 05-22-2014 04:12 AM
just starting out mortachi Cosmetic Modification (Interior/Exterior/Lighting) 3 10-06-2013 10:23 PM
