Old 05-14-2018, 09:45 AM   #1
azonic
Drives: 17 BRZ
usb / 3.5mm module size
Can anyone advise what correct size switches would fit where the standard USB / 3.5mm jack module is in the front pocket?
I want to put a on/off/on 3 way rocker in there to toggle camera feeds, but want the switch to look as OEM as possible.
azonic is offline   Reply With Quote
Old 05-14-2018, 10:09 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Mcmaster has drawings of all of their switches which you can then measure the opening you want it to fit.
https://www.mcmaster.com/#electrical-controls/=1cu6iya
BigTuna is offline   Reply With Quote
Old 05-15-2018, 05:43 AM   #3
azonic
Drives: 17 BRZ
after a bit more research I'm 99.9999% sure these are standard current toyota switch size of 32.5mm x 22mm
WTB: OFT Module chiu Canada Classifieds 0 04-11-2018 09:26 PM
WTB BRZ Always On Module Jordan Silveira Want-To-Buy Requests 3 08-08-2016 01:30 AM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
Led DRL Module hayleybeaners Cosmetic Modification (Interior/Exterior/Lighting) 10 02-20-2014 08:56 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
