Drives: 2015 Scion FRS
Squirrels, rats or critters in engine bay solution!
As stated in the title, I have found a way to prevent most critters away from chewing, or nesting in the engine bay all year round. I have tried dryer sheets, traps and mothballs. All of them failed and stunk really bad. So I used Tomcat Aerosol spray https://www.homedepot.com/p/Tomcat-1...0605/302683092. This does not stain the engine, does not stink or enters the cabin. You only need to use it once a month. Started applying this in January and a light coating on the entire engine and potential entry areas once a month. I have not seen a single branch/mud/dogfood/trash or chewed on component since then. Works for me and just wanted to share this idea with you! It does smell like peppermint/garlic when first applying but quickly goes away. I know it specifically says not to use it on the engine bay/ cars but I did and it works.
Drives: 2014 Subaru BRZ
I would be worried about this gumming up my engine..
theirs a reason they warn not to use it on wiring/ battery / engine (to save there ass) some of the reviews even mention it being "sticky" |
I can see your concern but I don't see it happening unless you douche it on there, you know? So far with over 4 months of use engine bay is not sticky or collects dirts. When I say light coats, I mean light coats.. but again I can understand your concern.
Thanks for the input!
Country Boy 4 Life
I live chatted with Tomcat a few minutes ago. They are saying not to use it on engines because:
It is flammable. They have not tested it on engines. Liability reasons. Sodium lauryl sulfate and sodium benzoate are pretty safe chemicals. the first is used in toothpaste and the second is a food preservative. The essential oils are self explanatory. I had Norwegian rats in my engine bay...
I LIKE TIRES! |
The Gunshine State
Drives: '14 BRZ Limited
I just put a cat in mine.
Don't feed said cat.
![]() Current DD: M235i |
Country Boy 4 Life
No, not the one I caught one with a small bear-style trap that I chained/staked to the ground. It weighed 13oz and from nose to tail tip, stretched across the entire lid of a normal 33gallon trash can. like this one... Can't find my pic right now... Little crapping BASTARDS! My engine stunk for awhile. I have since moved out of the boondocks and no longer have a rat problem. via Imgflip Meme Generator
I LIKE TIRES! |
The Fail Boat
Drives: CWP S.B.
I Just wanna know if OP lives under a tree. Post a picture of your front yard!
*1 I didn't have tis problem when I used to live in the northwest. XD *2 I did live in the middle of a neighborhood atop of a small hill.... so maybe that helped. Back to topic, why not just spray it inside the wheel fender/By undercover & near wiper area....instead of the engine bay? It's not raining no more. |
| FS: Perrin 3" Intake, Torque Solution engine mounts | jonesy | Engine, Exhaust, Bolt-Ons | 4 | 01-10-2017 04:03 PM |
| Rats in my FR-S | KR-S | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 12-31-2015 11:53 PM |
| Critters chewing on my car. | feedbag | Issues | Warranty | Recalls / TSB | 9 | 03-29-2013 11:06 PM |
| rats or mice chewing under hood | decoratordm | CANADA | 3 | 01-08-2013 03:36 PM |
