Old 05-09-2018, 10:27 PM   #1
mcrane
mcrane's Avatar
Hesitation/Misfire under boost
Car: 2013 Scion FR-S
Mods:
K&N High Flow Filter
Custom Intercooler Piping
Water/Air Intercooler with Bosch Water Pump
Garrett GT28 Turbo (Internally Wastegated)
Turbosmart BOV
Innovate SCG-1 Electronic Solenoid Boost Controller/Wideband
Mishimoto Oil Catch Can
OMNI Power 3 Bar MAP Sensor
Bosch 550CC Injectors
NGK Iridium Sprk Plugs (.28 gap)
CP Pistons (Stock Compression)
BC IBeam Rods
King Bearings
AEM High Pressure Fuel Pump
ACT Stage 4 Clutch
ACT Lightweight Flywheel
TRD Catback Exhaust
Custom Up pipe and Downpipe
Issue:
Vehicle was dyno tuned with DW 700CC Injectors. Tuner had a difficult time getting the car to idle. After 6 hours, he was able to get it to idle. A couple hours later the vehicle was making power. Tuned to 250hp. After leaving the tuner, a noticble hesitation and stumble occurred at 4000 rpm consistently. The vehicle would misfire and shake and die when stopping. This only seemed to occur under boost at 4000 rpm. Sometime the vehicle would pull clean, but generally it would hesitate each time. At high speeds (highway) the vehicle seems to be fine. The vehicle does not do this with the Stock Injectors and MAP Sensor. Also, the car does eventually build full boost once it moves past the stutter.
Replaced:
Coil Packs
Spark Plugs
MAP Sensor
Cleaned the MAF
Swapped to 550cc injectors
Vehicle was brought back to tuner with 550CC injectors. Once on the dyno, the tuner noted the hesitation. He noticed that the when putting he AFR sniffer in the drivers side tailpipe, the AFR was rich. But in the Passenger Side Tailpipe, the AFR was Lean. He eventually got a good read and tuned the vehicle to 270hp before it started having symptoms of a slipping Clutch. Once on the street, there was no hesitation and no clutch slip whatsoever. The vehicle did however pull timing on the street. He added 10% fuel to beef it up and remove knock. The car pulled clean all the way home (100 mile drive). Towards the end of the drive, the car developed the hesitation once again. This time between 4,000 and 5,000 RPM
At this point, the MAP Sensor, Coil Packs, Spark Plugs, and injectors have been changed out. The original 700CC injectors were tested and returned from DW with a clean bill of health. So it isn't the injectors.
CODES encountered throughout the process:
Random Misfire detected
U0155 - Instrument Cluster Communication
Idle Air Control High Output
This is driving me crazy. Does anyone have any ideas what could be causing this? Thanks.
mcrane is offline   Reply With Quote
Old 05-10-2018, 01:49 AM   #2
Cal3000
Drives: Panda FR-S
Similar thing was happening to me, but it was the coil pack.
If you changed out your coil pack and plugs, then I would look at the direct injector seals next. That could cause hesitation. Which cylinder are you misfiring in? Get a compression test. There are also special cases when the direct injector gets too hot, they can malfunction.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 05-10-2018, 07:41 AM   #3
mcrane
mcrane's Avatar
The misfire is occurring in all cylinders. When plugging in the Snap-On, all Cylinders are misfiring.
Old 05-10-2018, 08:31 AM   #4
Fred E
Drives: WRB BRZ
Can you share any datalogs of the misfiring/hesitation?
Fred E is offline   Reply With Quote
Old 05-10-2018, 04:14 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is the tuner used to the platform? Sounds like it could be trying to run the DI too close to the spark event.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-10-2018, 05:36 PM   #6
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Had the same problem it was coil packs took forever to find out what was causing it..
Sent from my SM-N950U using Tapatalk
SoCal80six is offline   Reply With Quote
Old 05-10-2018, 06:00 PM   #7
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
Have you done a boost leak test? Also, make sure your MAF sensor is clean
Edit: just saw that you already cleaned the MAF
kimcheefists is offline   Reply With Quote
Old 05-10-2018, 06:44 PM   #8
mcrane
mcrane's Avatar
Replaced all four coil packs
Old 05-10-2018, 06:46 PM   #9
mcrane
mcrane's Avatar
DI and PI are always running. Plus, it doesn't do this with the stock tune and injectors/MAP
Old 05-10-2018, 07:36 PM   #10
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Mods:
Turbosmart BOV
GFB Manual Boost Controller
BC IBeam Rods
King Bearings
ACT Stage 4 Clutch
TRD Catback Exhaust
Glowshift Boost Gauge
Issue:
Replaced:
Coil Packs
Spark Plugs
MAP Sensor
Cleaned the MAF
Running rich I think. Got the same thing when I ran my blower tune on NA lol, felt like clutch slippage. Car would die randomly
________
~refer to username~
idkwhatimdoing is offline   Reply With Quote
The Following User Says Thank You to idkwhatimdoing For This Useful Post:
mcrane (05-10-2018)
Old 05-10-2018, 08:23 PM   #11
mcrane
mcrane's Avatar
Originally Posted by idkwhatimdoing View Post
Running rich I think. Got the same thing when I ran my blower tune on NA lol, felt like clutch slippage. But when driving on the street he detected no slipping
________
~refer to username~
The tuner said it felt like my Clutch was slipping on the dyno and it does die randomly.
Old 05-10-2018, 08:51 PM   #12
idkwhatimdoing
Engine dying randomly isn’t a symptom of clutch slip. If your rpms stutter at a certain rpm, it’s not the clutch. 4k rpm i believe is a transition state for the injectors between DI and PI, i forget which kicks in at that point. During clutch slippage, the rpms will spike. Is that happening?
________
~refer to username~
Old 05-10-2018, 09:00 PM   #13
mcrane
mcrane's Avatar
________
~refer to username~
I misspoke. It only died after resetting the fuel trims. Once it relearned it was fine.
Old 05-11-2018, 12:09 AM   #14
sid94
Drives: 2013 frs
Put oem plugs in it. They’re good for pretty high hp. I had a random cylinder misfire code when I was breaking in my engine cause I had put a set of ngk “for break in” and it would throw me that code and hesitated like a old man before farting. Swapped oem plugs and car ran great after that
sid94 is offline   Reply With Quote
Engine Hesitation for 1-2 seconds. phoenixrage Issues | Warranty | Recalls / TSB 9 07-14-2015 05:18 AM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
RPM hesitation on WOT? Yamajee Issues | Warranty | Recalls / TSB 8 01-10-2015 12:43 PM
Hesitation right off idle D K Software Tuning 5 06-03-2014 04:41 AM
