Old 05-08-2018, 12:16 PM   #1
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
2017 86 dead in the water
I have not driven my car in a week.
Keyless did NOT unlock it. I used the key. Zero power, no lights, no warning bells. Battery 100% dead. There was nothing electrical left on in the car.
I have not tried to jump it yet, but I have tried several of my hi tech battery chargers and none of them recognize being hooked to a battery when properly connected. Even when hooked to a fried battery these chargers typically recognize a battery and give me a bad battery indicator, in this case they indicate they are not hooked to a battery at all. Very weird that they do not recognize a battery.
Zero previous battery/ car issues. Almost all stock.
Broken plate? internal meltdown?
Evap pump just killing the battery while sitting for a week? Often his thing sat for a month during the winter with zero issues.
18 months old, 8K miles. 1.5 hours to closest Toyota dealer.
I have other cars to drive, but I am really busy for the next 60 days. I do not really have the time to diagnose this problem, does this seem familiar to anyone? Common issue?
Thanks,
Scott
SCQTT is offline   Reply With Quote
Old 05-08-2018, 12:27 PM   #2
ermax
ermax's Avatar
Thanks,
Scott
Most charges will have a hard time charging a completely dead battery. If it's a manual, try pushing it and then go directly to the parts store for a new battery.
Old 05-08-2018, 12:39 PM   #3
Thanks,
Scott
Completely dead with a no battery indication is a new one on here. Check your cable ends to make sure they are tight.
Mine has sat for 2 weeks and started first try. Even left the trunk open for 18 hours and there wasn't the slightest hesitation. Something else is up with yours. You are 100% positive nothing was left on?
Old 05-08-2018, 01:04 PM   #4
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
I don't think there is any way to push start it without the ECU and FI being pressurized.
There is a little block on the battery cable (bolted to the battery) with two very small fuses built in. Looks like one of them may be popped.
Still seems very strange, like something in the battery broke or melted down.
I can hook my chargers to a battery that has been dead for 10 years and it will still recognize that it is hooked to an actual battery.
Old 05-08-2018, 01:11 PM   #5
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
www.batterytender.com/Battery-Basics
Battery Tender won't charge a completely flat battery. Needs at least 4 volts to get going.
One way to do this is to jumper to a good battery for a few minutes.
And a multi-meter to see where you're at.
Also probably not recommended.
Old 05-08-2018, 01:19 PM   #6
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Understood, like I said my battery chargers are pretty high tech. I can hook them up to a battery that has been dead for 10 years and they still realize they are hooked to a battery. On this thing they think the leads are connected to nothing.
That little block with fuses attached to the battery, Subaru Toyota part only? replace the whole thing? looks like the blades themselves are NOT replaceable.
Old 05-08-2018, 01:52 PM   #7
That is probably your issue. Yes they are a Toyota/Subaru part. Did you check the charge on the battery to see if it is indeed dead? Your charger probably does that?
SCQTT (05-08-2018)
Old 05-08-2018, 09:59 PM   #8
humfrz
I'd suggest you replace the fuse blocks. Meanwhile, while you are buying a new battery, have the old battery "load tested" ...... just for giggles.
humfrz
SCQTT (05-08-2018)
Old 05-08-2018, 10:36 PM   #9
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Battery out of the car, nothing. I wonder if it had an internal meltdown. Batteries are an hour from where I live so It is nothing I can deal with for a while. Weird.
Old 05-08-2018, 11:02 PM   #10
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
I drive my car once a week, maybe. Have since I owned it. Never a hesitation to start.. and it's got 45k on it. Sounds like something else is going on.. take it to the dealer.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 05-09-2018, 01:58 AM   #11
humfrz
Where on earth do you live ??.......
humfrz
Old 05-09-2018, 08:20 AM   #12
Very weird. I could see the battery issue if you didn't have the blown main fuse. The two combined are strange. You hadn't done anything that could have caused a dead short in a main cable did you? Toasted the battery and blew the fuse?
Old 05-09-2018, 08:46 AM   #13
cjd
cjd's Avatar
Drives: 2017 BRZ
I had a battery short out internally once. It took the body computer with it. I could see something like this popping a fuse, and then being totally dead next time you tried reading even voltage from it if it sat a while after. Mine happened in the middle of a turn on an autocross course...
The Following 2 Users Say Thank You to cjd For This Useful Post:
Tcoat (05-09-2018), Tristor (05-09-2018)
Old 05-09-2018, 08:48 AM   #14
OK I can see that. Sort of the reverse of what I was thinking.
cjd (05-09-2018)
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 08:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
(S)he's dead, Jim. D.Scrye Scion FR-S / Toyota 86 GT86 General Forum 37 02-11-2016 03:40 PM
Dead Pixel? Cliu91 Issues | Warranty | Recalls / TSB 2 11-12-2014 08:40 AM
