Drives: MY15 Subaru BRZ
19x9.5's all round
Has anyone ran 19x9.5 all round with 245/35 19 +38 on the front and rear.
I Love the concave concept CC03s in the 19" but just worried they will scrub in the front. Just wondering if anyone else has fitted 19x9.5 on the front without issue and if im better off going 18x9 245/40 +38 |
Drives: 2014 GT86
Go for 24x9.5". Just get rid of tires. No one else will have that setup!
Ive read the tire directory and cant get a clear answer. The first post on the 19x9.5 +38 on the directory states it wasn't his car so i stopped reading on second look they posted further down more info thanks. There also running 225/40 which i thought was a bit risky of the wheel popping off the bead with that much stretch
The street FX build doesn't go into detail on the 19x9.5 set up as they change them out later for a staggered set up when they flared the guards. |
A Nobody
Drives: FRS
just make sure you get some chrome spinners for a perfect fit
#5 | |
Country Boy 4 Life
The will "fit" with: 245/30/19s (which are closer to the correct diameter), coilovers w/tophats, rear lca, end links, and possibly other suspension parts. Camber is needed in the front and rear: -2.5+ is my estimate. 18'S may be better for you. 245/35 is the correct diameter in 18.
I LIKE TIRES! |
Sarcastic SOB
With 19's you will need 20 profile tires. Basically solid rubber, no inflation required.
| The Following User Says Thank You to wbradley For This Useful Post: | Leonardo (05-08-2018) |
Country Boy 4 Life
19x10.5 +32 235/30/19 all around. To my surprise: The rear actually fits! LOL
You can tell the rear fenders have not been pulled either!!! http://www.ft86club.com/forums/showthread.php?t=23831
I LIKE TIRES! |
#8 | |
Thanks for the helpful answer rather then being a sarcastic asshole. Personally I think the Street FX 86 looked great with the 19x9.5's on it and I love concaved rims. Unfortunately getting a decent concave on the 86 is difficult as you rather need alot less offset or larger diameter and you still have to buy whats available. |
#9 | |
Country Boy 4 Life
I LIKE TIRES! |
| 19x9.5 +44 All Around | Egyptn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 10-06-2015 07:01 PM |
| HRE Flowform FF01 - 19x9.5 +43 | DonkeyKonga | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 07-09-2015 12:59 PM |
| FS: ESM 004 19x8.5 +35, 19x9.5 +38 | jher | Wheels and Tires | 3 | 09-19-2014 09:04 PM |
| will Volk 19x9 fit? | BRZ888 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 02-03-2014 01:41 PM |
| 19x9.5 with +38!? All Around | mikeTee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 08-25-2013 02:02 AM |
