Drives: 2013 BRZ Premium
Tein Flex Z Spring Rates
Hello all!
A question for the suspension guru's... Can you change the spring rate on the Tein Flex Z's? If you do change the spring rates, how badly will it affect the ride quality? Im not trying to go with 16K spring rates, more along the lines of 8k spring rates, since the Flex Z comes with 6K spring rate. I have tried searching and googling for an answer about this, but was unable to find and answer, or any info about changing the spring rates on the Tein Flex Z coilovers. I recently purchased the Tein Flex Z because my factory shocks with RS-R lowering springs were shot and felt bouncy all over the place. I went with the Flex Z because I have always had great experiences with Tein products, and I got a killer deal on the Flex Z's brand new. I had read that they are a little softer than others, and that they dont go as low as other coilovers on the market. Unfortunately I have to have the coilovers in the front almost maxed out as low as they can go without changing preload in order to get the ride height im looking for, not slammed but also not much wheel gap. The problem is that the coilovers are too soft for my liking, and since they are soft, the tires will rub under hard cornering over small bumps. The car will also rub sometimes while very slowly pulling into parking lots, driveways, ect. I have already cut and clearanced alot of the car to make the wheels fit as I am widebody and running 255/50R16 tires, but still have some rubbing issues so I want to go with a higher spring rate. I understand that Tein matched the shocks for the spring rate, but is it so accurate that changing the spring rate slightly will have some adverse affects? I know people change out the spring rates on coil overs like BC Racing without too much adverse affect, is that because BC does not build the shock to match the spring rates like Tein does? TIA |
You need monosport, not flex z. Best price =/= best for your application.
#3 | |
Mike, I know you have alot of knowledge around the Tein coilovers, could you please shed some light on what affects changing the spring rates to 8K would have? |
I wouldn't recommend it. It'll ride like crap. Save up, and buy coilovers that are designed for the spring rates you wish to run.
Drives: GR Corolla
I think the Flex Z does a good job of eliminating wheel gap. I did have to adjust the rear pre-load to get as low as the front tho.
![]() I'll only rub if I corner really hard, but then again, I'm running 245/40/17 tires on 17x9 wheels. I used to daily drive it just like that and only ever had issues driving on gravel (actually got stuck and had to be pulled out on 3 separate occasions). |
Drives: Frs
raise the ride height some and use the flex z as they come?
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Maybe my point is not being conveyed correctly.... I want to try and make the tein's a little stiffer. Not crazy stiff, something along the lines of a 8-10K spring.
I understand that I did not buy the best coilover for my purposes at the time. I understand that I can raise the ride height to combat the rubbing issue. I understand that Tein designed the damper to work best with that spring rate. I understand that changing the spring rate on the Flex Z's is not the best option in the world. I'm not trying to slam my car, just get wheel gap that I can only fit one or two fingers in. I asked these questions on this forum and not facebook hoping to get some actual insight, not just "It'll ride like shit", or "raise your ride height". I was hoping to start a discussion so that myself, and others can learn more about setting up, or modifying an existing setup. I know people change out the spring rates on the Flex Z's on other platforms like WRX, Miata, S2000 ect. After market companies sell springs for the Flex Z in different rates for other model cars, so I figured maybe we can change the spring rate on the Flex Z for the 86 as well. Maybe Tein valved the dampers on the Flex Z so precise for the 86 platform that other springs rates will perform very negatively on those dampers? Most other coilovers for the 86 platform have options to change out the spring rates, Swift makes alot of spring rates for different coilovers. But I have not seen any for the Tein Flex Z. I do plan on getting a more track oriented coilover in the future, but that is not going to be anytime soon. (Sorry im not a baller like some of you guys ) So I would like to try and make the Flex Z work better for my setup, instead of just living with the issues.Also one other thing if anyone has some insight on, if I have the damper adjustment set to the stiffest setting, will it damage the damper over time, or will it be fine running them 24/7 on the stiffest setting? Im currently 2 clicks away from the stiffest setting because im worried I may damage the damper by daily driving them on the stiffest setting. |
#8 | |
It *will* make your car ride like crap. You really should consider the opinions and feedback from those more experienced than you. Isn't that why you made this post? Why do you want to street drive on the stiffest setting? Do you know what the damper adjustment actually does? |
LMGTFY
Drives: 13 FRS, 91 Miata
You have your answers.
1: Change the spring rate to reduce compression. (It will ride like shit) 2:Raise the car. Or even better what you should have done from the beginning... Buy right not twice. What more do you want? Your too low on too wide a tire. There are only so many things that can be done. If you can't even afford decent coils maybe you should have not gone wide body huh? |
#10 |
Drives: 2014 Subaru BRZ
slacker221, adjust the preload and give it a shot, see how you think it feels
"rides like shit" is subjective these guys are like Hyper track oriented... |
#11 | |
Drives: 2013 Scion FRS Series 10
*by no means am i a professional, just my two cents from my own personal experience |
#12 |
Drives: 2014 GT86
Student Driver: Flex A can be revalved. Z was designed with unrevalveable/unserviseable damper inserts to get costs down.
As for OP .. My first choice would be not drop stupid low Second choice would be (if that gap THAT much bothers) to reduce it via other means, eg. fender extensions like this, this, this or this for suspension to still be functional as intended instead of sacrificing function for sake of arguable form My third choice would be sell off Zs and buy instead something that was designed for what OP wants, with that low drop and that stiff spring rates. |
#13 |
You know, OP could also just get better offset wheels... he is widebody after all.
Kinda funny cuz he runs 255 on a widebody, and I run 265 on a stock body, and I have zero rubbing issues. And I run 6k springs on my CSG Flex A. |
#14 |
Drives: 2014 GT86
CSG Mike: maybe alignment/camber (which i doubt you running stock) plays role in clearance? Also width aside, his wheels are also of high sidewall and R16. +5.7%/1.4" diameter. You probably have more reasonable sidewall profile to go along the wider width.
So it looks like "meaty tires" in addition to flushness/stance (who knows, possibly also stretch, depending on wheel width) from "looks trends" are prioritized .. i wonder why performance/comfort matters at all for him. |
| Spring Rates | Student Driver | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 08-08-2017 11:57 AM |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 09:33 PM |
| 2015 FRS spring rates? | Ubersuber | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 02-05-2015 08:27 PM |
| Help On Deciding Spring Rates | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 11-18-2014 02:18 PM |
| Anyone With Custom Spring Rates? | Sprinter | Tracking / Autocross / HPDE / Drifting | 3 | 05-13-2014 12:12 AM |
